Can anyone recommend a good audio test CD or other hardware that can test the response of speakers and audio system in general?
Hopefully, not tooo expensive... TIA,
Sam Kanter, NYC |
#2 |
What exactly are you trying to accomplish? Do you want to produce graphs for XO design or are you just testing levels, etc. for setup purposes?
#3 | |
Sam Kanter, NYC |
#4 | |
And what is your goal? To fine tune a completed design, or build speakers starting from scratch?
Aerodynamics are for people who can't build engines. Enzo Ferrari |
#5 | |
I assume a meter is a more accurate method of testing than just the ear, but cost is a factor. Can you tell me what my options are, and approximate costs of testing CDs, hardware, software, etc.? TIA,
Sam Kanter, NYC |
#6 |
Depends on how accurate you're trying to be. The cheapest method would be to download some MP3 test tones (free) run that through your amp and use a Radio Shack SPL meter to measure response. This is not very accurate but will give you an idea if you made things better or worse. A more accurate method would be to get a measurement microphone ($30) and you might need a mic pre-amp (another $30) and some measurement software like True RTA or JustMLS ($100). There's some software that's less expensive (maybe free) but I've not used it. Someone else probably knows about it.
#7 |
Don't forget speakerworkshop from http://www.audua.com/ - it's free and does a nice job measuring output. Add a WM-61 capsule, a 5532, a couple resistors and a battery you can make a decent measurement system for $25 or less.
#8 | ||
Thanks...I'll try the free software first and see how it checks out.
Sam Kanter, NYC |
| Audio test CD - Free for anyone to use | tuck1s | Parts | 1 | 16th September 2008 11:39 PM |
| Audio-test software | hugobors | Solid State | 7 | 11th February 2006 01:50 PM |
| FREE Audio Test CD!!! | seangoesbonk | Everything Else | 13 | 16th May 2005 01:39 PM |
| Digital audio test CD | kello | Swap Meet | 19 | 24th August 2004 06:34 AM |
| Page generated in 0.09947 seconds (76.72% PHP - 23.28% MySQL) with 10 queries |
