Hi, I'm building Vifa towers (Or I will be if my router ever arrives) and I'm wondering if I should leave a way to get the back off should I ever decide to change or have to fix the crossovers. Pulling the woofer out leaves a long reach down with two braces in the way. What do you guys do?
Tony
Tony |
#2 |
diyAudio Moderator Emeritus
A question that plagues my mind too, but I go for the complete seal to get the max out of bracing. I can't see it being much good just pushed against a removable panel.
Personally I would keep the crossovers outside the tower if you feel you need access to it, or make a seperate removable crossover enclosure within the main sealed enclosure.
"The human mind is so constituted that it colours with its own previous conceptions any new notion that presents itself for acceptance." - J. Wilhelm. (But I still think mine sounds better than yours.) |
#3 |
You can attach the whole crossover module right behind the woofers with one screw through the middle of the board..so this way you can reach it.....or if you use on of those 3 inch speaker wire connections with the gold binding posts at the bottom of the tower you can always put it right behind there...
#4 |
Good idea on the terminal panel. I guess I'll make seperate crossover boards for the drivers, that way thy will fit out the hole if needed.
Tony
Tony |
| Quick valve construction question | eeka chu | Tubes / Valves | 25 | 28th February 2006 09:20 PM |
| I'm sure this has been asked before somehow, but...(Fostex BLH construction question) | jim_vt | Full Range | 4 | 29th September 2005 01:01 PM |
| Baffle construction question | Christof | Multi-Way | 2 | 18th February 2005 06:18 AM |
| woofer construction question | swest | Multi-Way | 4 | 20th May 2004 02:41 PM |
| HELP Sub box Construction question | mikee12345 | Multi-Way | 3 | 23rd May 2003 03:18 PM |
| Page generated in 0.06889 seconds (72.15% PHP - 27.85% MySQL) with 10 queries |
