What are some good example of baffle design to improve diffraction
Old 27th August 2017, 05:22 PM   #11
sootboots is offline sootboots  Canada
Originally Posted by GM View Post
Open cell foam [supra, depending on the app] baffle is my preference.
GM
This sounds affordable. Can you show a pic or two as an example?
Thanks,
John
Old 27th August 2017, 06:18 PM   #12
Grasso789 is offline Grasso789  Germany
Old 27th August 2017, 11:19 PM   #13
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
TThe Sonus Faber Ellipsa (pictured earlier in the thread) was the last commercail speaker to catch my attention. It inspired our “ellipse” shaped enclosure. Wide baffle that curves away from the drivers has low diffraction and the wide baaffle allows a low XO point (160-180 Hz):
We have found that the big champhers on the sides of our miniOnkens goes a long way to reducing diffraction signature, and that the trapezoid version that mimics a tear drop in plan reduces it even further (trapezoid sitting on a larger rectangular miniOnken):
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 27th August 2017, 11:27 PM   #14
Bigun is offline Bigun  Canada
Bigun's Avatar
That ellipse looks nice Dave, makes me wonder if we shouldnt put speakers right up against the front walll with some attempt to blend in the appearance ?
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
Old 27th August 2017, 11:32 PM   #15
scottjoplin is offline scottjoplin  Wales
scottjoplin's Avatar
The Jordan VTL is 4 inches deep and recommended placed against the front wall
Woofer Assisted Wideband is the New Testament renounce the anachronistic acronym FAST
Old 27th August 2017, 11:48 PM   #16
frugal-phile(tm)
planet10's Avatar
They typically get put 8-10 out from the wall, closer would be difficult without moving some clutter.
dave
Old 28th August 2017, 01:10 AM   #17
eriksquires is offline eriksquires  United States
eriksquires's Avatar
So the issue with absorbent materials, is they don't absorb uniformly and can alter dispersion characteristics. This non-uniformity of absorption can make the polar plots funky.
Having said this, I am not above putting felt around a ring or dome tweeter. I find this actually helps a great deal.
Still, given a preference, and living room, I'm a wide-body fan all the way. Flat or curved, much more energy gets pushed into the room before diffraction occurs with a narrower beam, improving detail and smoothing out the FR.
All of my successes and failures can be explained by my attempts at getting a girlfriend. All of them.
Old 28th August 2017, 01:18 AM   #18
Of course, one of the most if not THE most expensive uber-wide speaker ever:
Old 28th August 2017, 01:23 AM   #19
What are those? Swans did some stuff that looked like that
Old 28th August 2017, 01:33 AM   #20
rayma is online now rayma  United States
IRS
What are some good example of baffle design to improve diffractionHide this!Advertise here!
Baffle edge diffraction vs baffle step skogs Multi-Way 47 21st August 2016 05:15 PM
Best material for baffle to help diffraction? Stewart Holmes Multi-Way 35 15th February 2014 02:40 PM
Edge diffraction: large, rounded baffle, or narrow square baffle fortyquid Multi-Way 23 12th February 2013 02:23 AM
Baffle Diffraction Simulator Tenson Multi-Way 0 12th December 2006 02:56 PM
new speaker baffle design concept...good or not? thadman Multi-Way 4 20th November 2006 01:15 AM
