My Tad TSC3415 Theater Speakers
If everything works out and i think it will.I have this pair of Tad Bass Bins that will be transformed into my 4 way system pair . With TD4001 drivers and ET703 super tweeters. Sub woofer has four TD1603's .They are beautiful as envisioned.
The wood horns are Rey RH3'S or similar.
Going to be working on the crossovers may need help.
It's hard to find a single horn that will hold an ultra tight pattern (like 20 degrees) on it's own to a low enough frequency. The speaker system posted uses woofers placed in the diamond pattern (this is said to control radiation vertically and horizontally) and the two horns stacked to tighten the vertical radiation.
