What is the best method for cutting the holes for speakers? I have seen the router templates that Parts Express sells. Just not sure how they will work.
I will be flush mounting them as well. So I assume once the hole is cut, I will use a rabbit bit on my router to allow the flush mount. I looked at using a jigsaw, but it's impossible to get a clean cut. What's the preferred method? |
#2 |
I have a circle cutting jig I bought at Sears for about $20. I'm pretty happy with it. It doesn't have any measures on it like the jig PE sells, but I'm not sure I'd trust the jig's measures anyway.
#3 |
Is it used with a router?
If so, what type of bit do you use? |
#4 |
DIY circle cutting jig:
Aerodynamics are for people who can't build engines. Enzo Ferrari |
#5 |
diyAudio Editor
SB,
IMHO the router should always be the first choice for circles. I use the plastic Sears jig and it's fine. For recessed driver mounting, I first cut the larger recessed part, to full depth on both speakers, It usually takes a couple of passes to get the width that you need, I do equivalent cuts on both speakers before changing adjustments.- a pain , but keeps the sizes consisitant. T I reduce the diameter more to the hole size I want and run a circle, increase the depth ,then run another circle until I'm through About 1/4" is as deep as I go on a cut. I use a bit that makes a flat bottomed groove. Get Carbide bits |
#6 |
I tried a jig saw to cut a hole a few times & the best I could ever do was barely fair. Mostly they looked like my dog gnawed the holes for me. Router is the only way to go IMO.
I spent the $30.00 on this jig, and it is well worth it. You do have to drill holes in it to match up with the holes on your router. http://woodworker.com/cgi-bin/FULLPR...0&LARGEVIEW=ON You can make the same jig out of a $6.00 piece of acrylic from Home Depot, but cutting the recessed slot on the bottom just wasn't worth the effort for me. The nice thing about a jig with a slot though is that you can set it to the precise hole size you need.
Probably a silly question, but ........ |
#7 |
Also the size matters. If I can I always use hole saws. But those only usually go up to 4"-4.5". But these are the most convenient and precise for me.
For stuff like woofers, I usually use a compass and draw the circle, and then use a hand scroll saw. Always works for me. However I don't have a house yet, so I'm limited to hand tools. The ways described above using the routers are much better. Except for the small holes, I still think hole saws are the best method (for standard round holes that is).
I enjoy my organic shapes..... |
#8 |
diyAudio Editor
I have a 4" hole saw. I tried to cut my 15" woofer opening with a jig saw. Try a router and you never go back!!
#9 |
I think the router with a circle cutting jig is by far the best way to go. Doesn't matter if it is homemade with a piece of masonite and a pin or a Jasper Jig which for the person who was cautious about it's accuracy is dead on accurate.
Unfortunatley not every has a router and the thought of spending any more money on tools to make a set of speakers (especially a 150 router plus 20 1/4 straight bit plus the 30 jig) causes me strain these days. Here is an option that you can do with a jig saw. Take any strong 1/4 inch material (masonite, luan, etc) that is bigger by about 4 inches over the radius of you circle to be cut and hotmelt glue it to the bottom of your jigsaw foot. Now take your 1/4 inch drill bit and drill a hole the radius of your speaker cutout away from the outside edge of the blade. Grab a 1/4 dowel or pin and drill a hole at speaker center and you are ready to make a pretty clean cut. You will need to drill a pilot hole for the jig saw blade as well and be very careful as you come around to where you started but I think you will be very satisfied with the hole. |
#10 |
Banned
| Dip Hole clogged | chipmonster | Parts | 10 | 7th February 2008 05:20 AM |
| What to do when your hole is a bit big? | tommytube | Multi-Way | 6 | 13th September 2005 02:08 PM |
| Is it worth cutting a hole in my wardrobe for a subwoofer?? | SkinnyBoy | Subwoofers | 12 | 21st January 2003 07:04 AM |
| Best method for cutting driver holes? | dc | Multi-Way | 16 | 29th May 2002 12:27 PM |
| Page generated in 0.12747 seconds (79.96% PHP - 20.04% MySQL) with 11 queries |
