DIY PMC MB2 clone
DIY PMC MB2 clone
Old 21st October 2017, 02:19 PM   #101
WalterPPK is offline WalterPPK  Netherlands
The caps came in today
Old 21st October 2017, 02:20 PM   #102
doublepost
Old 25th October 2017, 07:27 AM   #103
Heraldo Jones is offline Heraldo Jones
Looking great!
Old 25th October 2017, 07:51 AM   #104
wae is offline wae  Netherlands
Can you post how they sound???? Would be a nice Internet enhancement on the DIY website. Plug in on a channel and listen....
Great job
"If i ain't broken, DON'T fix it"
Old 25th October 2017, 04:09 PM   #105
You need to have some patience I'm still painting the cabs. We tested the OpenDRC and found out it has a base latency of 15ms. This is too high for direct monitoring. Still searching for an alternative.
Old 25th October 2017, 04:48 PM   #106
Charles Darwin is offline Charles Darwin  United Kingdom
You may have just found out why to my knowledge no manufacturer of studio monitors uses FIR filters.
Very nice job on the cabs though!
Old 27th October 2017, 11:46 AM   #107
RudeWolf is offline RudeWolf  Latvia
Kii Audio and Grimm Audio use them, same for KS Digital and Neumann (KH80). The problem is not FIR in general, as it can be made zero latency. Usually phase linear filtering requires long buffer times, therefore latency can jump up to triple digits.
From what I've heard, most of the time there's a way to implement both linear phase and minimum phase to retain similar filter curves, but trade phase coherency with latency when needed.
Old 27th October 2017, 07:37 PM   #108
Does the KH80 use FIR? We had the KH120 a while back but I didn't care for them.
Old 29th October 2017, 05:30 PM   #109
It does. Check the specs and you'll see that they're implementing phase correction - Georg Neumann GmbH - Professional Monitoring
As for the KH120, I regard it as a very good monitor for the price. Overall I'd say that nowadays it's rather hard to find truly horrid small 2-ways.
Anyways - I'm closely monitoring this thread as I have a need for a very similar design. Good luck!
Old 30th October 2017, 08:39 AM   #110
You're right but indeed with a bypass switch to go back to good old latency free IIR.
Would a Lake contour 26D be an option? It has very steep "linear phase" brickwall filters.
DIY PMC MB2 cloneHide this!Advertise here!
Clone of PMC DB1+ ??? Bigun Multi-Way 39 22nd April 2018 10:38 AM
PMC MB2S CLONE stargeezerme Full Range 41 30th December 2017 10:02 AM
PMC OB1 clone vincentrubble Multi-Way 5 28th October 2012 08:12 PM
fs PMC MB2'S...LOW PRICE!!! mitch112 Swap Meet 0 24th August 2010 07:59 PM
PMC XB2, MB2 vent dimension gengis Subwoofers 1 23rd March 2005 10:02 PM
