Baffle step and sensitivity question
I am interested on doing a 2 way system with top driver w8-1772 in a 1.5 cu ft sealed enclosure and the Beyma 10g40 in a ported enclosure.
enclosure width is not determined yet. maybe 12-14 in.
Based on the sensitivities of each w8-1772 and the 10g40 about 95db would this work?
No filter on the w8-1772 and a 2nd order on the 10g40.
Should i also throw the 10g40 on the rear of the enclosure?
I downloaded Edge and played around with that... but i am looking to use the 10g40 as compensation.
Thanks for any help!
w8-1772 in a 1.5 cu ft sealed enclosure [...]
Have you already seen this?
Tang Band W8-1772 Fullrange Loudspeaker Measurements Data and Information Full Range
It looks good / flat for a speaker of this type. I like the 30 degree curves.
Rule of thumb = a woofer that's +3dB relative to the top driver. I'd opt for a little more. It might depend on personal taste and how far off axis you listen.
Maybe consider this cheap Eminence 15" - see this model of the deltalite II (with 2nd order crossover), which looks about right for your project.
Greencones
No. Based on Rutcho's sealed box graph for the w8-1772, you'll have to run the helper woofer fairly high.
My suggestion is to use Edge and also a bit of trial and error with the baffle size + shape. e.g. make a (small) test box for the w8-1772 and experiment by tacking on wings made from scrap wood or cardboard. You should be able to find a layout that flattens out the 800Hz bump by about 3dB.
