Old 26th March 2004, 09:17 AM   #1
Hybrid fourdoor's Avatar
Default Using Panasonic FC's in crossovers?
Now I know everyone says ONLY USE bipolar capacitors in crossovers, but is this just for safe being? If you have a traditional amplifier with red being hot and black being ground (IE not BTL), can you use a "normal" capacitor like a Panasonic FC or whatever? Just as long as you pay attention to the polarity and don't hook it up wrong.
Seems like high rating (like 100uf) are hard to find in bipolar axial form.
I enjoy my organic shapes.....
Old 26th March 2004, 12:03 PM   #2
Hybrid,
You really don't want to use polarized electrolytic capacitors in a crossover. First, they're asymmetric and expect to have a DC bias. Despite what you might be led to believe by the red + and black - on the amplifier output terminals, there is no DC here (regardless of tube, transistor, bipolar, mosfet, single ended, push-pull, OTL, differential, or otherwise). You can wire two electrolytics "back to back" and have something that works but of course you need twice the value for each (the bonus is that you also get twice the voltage rating).
But more importantly, electrolytics sound like **** in a crossover. There's a reason people pay big bucks for poly and teflon caps in crossovers.
If you're looking for caps in the 100uF range, either you're doing a high-order design or a very low crossover frequency, like for subwoofer applications. Forget about passive crossovers for subs, you're much better off active.
Old 26th March 2004, 03:32 PM   #3
markp is offline markp  United States
Default Re: Using Panasonic FC's in crossovers?
Red does not mean only positive voltage in this case. The voltage out of the red terminal swings both ways relative to the black ground terminal making the cone move both in and out relative to its at rest position. That is why you need bipolar caps in a crossover, pos and neg voltages are present so there is no one polarity. You can use electrolytic bipolar caps but bypass them with a nice film cap of at least 10% of the value needed.
If it sounds good... it is good!
Panasonic EVJ 454Casull Parts 7 1st March 2009 01:06 AM
Another new sub from Panasonic.. ashok Subwoofers 4 3rd August 2007 09:48 PM
WTB Panasonic WM-61A neilyboy84 Swap Meet 3 31st January 2007 03:41 PM
Panasonic WM-62 or WM-66 instead of WM-61? NickZ Multi-Way 2 20th December 2005 01:02 PM
Panasonic FCs jonclancy Parts 8 17th August 2004 07:30 PM
Page generated in 0.08440 seconds (69.37% PHP - 30.63% MySQL) with 10 queries
