3d Printed acoustic lens, XT25, Thingiverse
Old 27th July 2017, 10:20 PM   #51
Gaga is offline Gaga  Europe
Just FYI - if someone might be interested: I'm trying to show a step-by-step construction, print-out, measurement of the 'Acoustic Lens' in a German DYI-HiFi-Forum here. I hope it's ok to point to a thread in another forum.
However, please indicate, if you might be interested in a specific piece of information given there, I'd try to translate and present it here then accordingly...
Gaga
Old 1st August 2017, 07:24 PM   #52
Megalomaniac is offline Megalomaniac  United States
Send a message via AIM to Megalomaniac
Anyone able to help me on the Sketchup software. The component I have on the right is the 2D lens im trying to rotate but doing so causes one side to be empty, how do I make it solid.
Old 1st August 2017, 07:35 PM   #53
I increased the number of segments on the circular paths to 360.
edit, i think when I made the arc segment I didnt change the number of segments. it must be having trouble lining up.
Still showing up as hollow
The Hat was able to be created fine
Old 2nd August 2017, 02:17 AM   #54
Figured it out, when you use the follow-me tool the circle you ride must be smaller or bigger than your revolution path, otherwise it does the opposite.
Old 2nd August 2017, 01:11 PM   #55
very nice!
Will you go to gmsh, import to ABEC and do a simulation?
Christoph
Old 2nd August 2017, 02:36 PM   #56
Originally Posted by Gaga View Post
very nice!
Christoph
I have never used either software. But I will attempt to learn it. I did a search and found your thread tutorials. You make it sound easy.
Danke!
Old 2nd August 2017, 07:49 PM   #57
Hi Megalomaniac,
Just indicate, if you need translations of the ABEC thread. Or may be post the *.step or *.stp file of your lens for download if possible. I could try a simulation as well...
Whatsoever, I'd be interested to learn more about your acoustic lens.
BW,
Christoph
3d Printed acoustic lens, XT25, ThingiverseHide this!Advertise here!
3D printed spiral enclosure fudce Full Range 32 26th April 2016 12:06 AM
3D Printed Chassis Jennifer G Parts 67 30th March 2016 02:46 AM
My 3D printed ToneArm Tankpopper Analogue Source 16 24th September 2015 03:50 PM
Formlabs 3D printed speaker driver laplace Full Range 1 30th January 2015 05:21 PM
3D printed supercheap speaker (mono) NicoMMF Full Range 7 14th October 2014 12:47 PM
Copyright ©1999-2017 diyAudio
