#41 |
Good, the DIY audio workshop realy is a hard hat area.
Ingvar |
#42 |
If anyone's interested, I had to send away for another midrange. I was getting some distortion and I originally thought it was due to an underpowered IGC amplifier. When I finally got off my lazy *** to investigate the issue, I discovered that it was the midrange in the left channel speaker that was at fault.
I sent away for another one from Parts Express, but I'm wondering how that could have happened. I took the speaker apart and I didn't notice any problems-- although I'm not sure what to look for. When it plays, the midrange sounds like garbled distortion, although you can still hear the sounds somewhat. I'm wondering if I could have blown the speaker through mishandling it or if it could be a factory defect. Anyone else ever had a similar problem? Any ideas why this went wrong? Kofi |
#43 | |
It could also be something as "simple" as a bad lead with poor contact either at the terminal connection or at the motor. In either case get a new one. Sherman |
#44 | ||
Oh well, I guess I can't be too disappointed. These speakers actually sound great even with the distortion, but its driving me nuts so its gotta go. Thanks for the advice. Kofi |
#45 |
Exchange midrange units between speakers to make shure there´s no problem in the filter, if distortion follows driver then likely Sherman´s right ,rubbing in voicecoil, probably due to careless handling in transportation. If distortion stays in the same cabinet, check filter.
Ingvar |
#46 | |
follow Ingvar's advice and check the problem isn't in the crossover. You'd also probably benifit in reducing the (physical) size of the crossover. Make the connection wires shorter(better yet, solder the component leads together where possible). Good luck with the new speakers. Regards, Tiago Quote:
#47 |
Thanks for the advice! I already checked the crossover and its fine. The speaker is distorting when I use it in my other stereo, so I feel prety confident that its the problem.
Yeah, I realize that I should have built the crossover more compact, but its really in the speaker good now, so I hesitiate to remove it. I sealed it in the speaker, so it woud be a real motherfather to get out. Just stupid on my part. I'll let you know what happens when I get the new midrange in. Kofi |
#48 |
Hey-- the bass in my speakers is causing rattle and distortion on certin bass frequencies. Not bad, but enough to drive you crazy once you hear it.
Multiple Chioce Question-- Do I need: (a) more stuffing? (b) less stuffing? (c) better isolation from the hardwood floor? (d) a new hobby? (e) other (please explain) _______________________________________________ Kofi |
#49 |
Does the "rattle" come from driver? If so check cabinet for leaks, mating surfaces between drivers and cabinet are often hard to keep airtight. Use selfadhesive rubber/foam or silicone windowsealers.
If rattling comes from something else excited by wibrations, try isolating speakers from floor and see what happens.
Ingvar |
#50 |
Rattling could also come from the filter "board" as it is fairly large it could vibrate against cabinet if not tightly screwed down. Internal wire could come into contact with speakercone at large excursions also making noices.
Ingvar |
| Newbie building d3A DRD 300B | stefanolo | Tubes / Valves | 8 | 3rd February 2007 03:51 PM |
| Newbie Aleph-X Building | lscangus | Pass Labs | 9 | 27th January 2006 01:21 PM |
| Newbie building JFET Zen v8 | summilux | Pass Labs | 12 | 26th January 2006 10:40 PM |
| Newbie at this speaker building! Please help! | JiggaD369 | Multi-Way | 11 | 23rd June 2005 01:38 AM |
| Newbie building speaker box. Help. | intelceleronman | Multi-Way | 14 | 29th October 2002 09:08 PM |
| Page generated in 0.11947 seconds (81.86% PHP - 18.14% MySQL) with 11 queries |
