Old 26th March 2004, 03:06 PM   #11
Kofi Annan's Avatar
Oh yeah-- and if anyone has any recommendations for hook-up wire for the crossover, I'd like to hear it. Otherwise, I'm guessing that my normal stranded wire will be OK.
Kofi
Old 26th March 2004, 05:43 PM   #12
Kofi Annan's Avatar
Anyone?
Old 26th March 2004, 08:11 PM   #13
The polarized elyts are not in series with signal sothats ok but parallel a small filmtype to improve hf properties.
The parallel method is always a good thing and the caps You´re planning to use are good.
This is some sort of knockout panel on the back of the speaker, I'd guess?
Right.
Internal wire- Use a good speakercable of moderate crossection area, a very heawy wire will need prolonged heat wile soldering and polypropylene (as most filmcaps ) are sensitive to overheating.
Ingvar
Old 26th March 2004, 09:28 PM   #14
Kofi Annan's Avatar
Thanks! That helps a lot.
Are you saying that instead of paralleling a 10uF and a 1uF polyprop together that I should use a 10uF polyprop and several small film-types together to achieve the correct uF value?
Also, what about the inductors? Again, Parts Express does not have inductors of certain values at the correct gauge. When I could increase the gauge I did so, but in some cases I was only able to decrease the gauge (i.e., from 18 awg to 16awg).
Will this cause a big problem? Should I try to order the correct gauge elsewhere?
Thanks in advance for any advice you can offer.
Kofi
Old 27th March 2004, 03:34 AM   #15
Gaucho is offline Gaucho  Canada
Gaucho's Avatar
You can parrallel two of the 18ga inductors to get a heavier inductor. An example to be real clear: place two 5mH coils (twice the desired final value) in parrallel to get: 2.5mH of inductance with 1/2 the DC resistance of one coil.
Not a big problem, you will just drop a little bit more voltage over the higher DC resistance. And if 16ga is the correct gauge 14,12 ,10...etc will be even more correct!
Good Luck,
Gaucho
Old 28th March 2004, 11:30 PM   #16
Kofi Annan's Avatar
OK-- last question, I think:
What's the deal with the "perfect layer" inductors. If I use these at 14awg in lieu of some of the 16awg / 18awg inductors, will this be OK?
Also, I am having to get 18awg in place of some 16awg inductors and I know that you (plural) have advised that this will be OK, but I am curious to know what the real drawback may be.
I know I'll drop some more voltage across the inductors, but as far as the sound goes, would I fly into an uncotrollable rage because it sucks so bad or would I only barely notice the difference between a midrange inductor at 20awg (bobbin-wound air core) and one at 18awg (air core, not bobbin-wound)?
Thanks again for all the advice. If there are any UN resolutions that anyone wants to recommend, I'd be happy to bring it up at the next open forum.
Kofi
Old 29th March 2004, 02:23 AM   #17
Kofi Annan's Avatar
Anyone?
I'm so lonely.
Old 29th March 2004, 08:20 AM   #18
navin is offline navin  India
navin's Avatar
Send a message via MSN to navin Send a message via Yahoo to navin
Gaucho
true. in fact i think that 2 x 18ga might sound better than 1 x 16ga. why?
well a few years ago i was trying to wind my own inductors. being a student of OVER engineering i decided to wind 12ga. man was that diffcult. the wire wold lold not cooperate. so to achieve the same DCR I took 2 x 14ga in parallel and wound with that. problem solved. later in the day i found a friend who was willing to wind me an inductor using 12ga (SWG) using a lathe machine.
when i replaced the my 2x14ga inductor with his 12ga inductor i was expecting a better sound but felt the sound quality had degraded. why i dont know. so i swtiched back to 2x14ga.
BTW "Perfect Lay" inductors are a brand. They use processes (might be a lathe machine) to wind inductors where hte wires are perfectly parallel and there are no air gaps. in fact i have seem hexa core inductors too where the wires have a hexagonal crosssection rahter than round. all this to reduce air gaps in the inductor. air gaps cause all sorts of losses that could be detailed/mentioned here but doing that would turn this post into a course in electronics.
...still looking for the holy grail.
Old 29th March 2004, 01:43 PM   #19
Kofi Annan's Avatar
Thanks for the explanation. I'd still like to know, however, if the sound difference between the midrange inductor at 20awg (bobbin-wound air core) and the inductor 18awg (air core, not bobbin-wound) is noticable to your average schmo.
Here's the crossover schematic if anyone wants to see it.
Only the 20awg, above, is available at Parts Express and I want to know if I should try to find another inductor elsewhere.
Kofi
Old 29th March 2004, 04:34 PM   #20
Kofi Annan's Avatar
Anyone?
Newbie building d3A DRD 300B stefanolo Tubes / Valves 8 3rd February 2007 03:51 PM
Newbie Aleph-X Building lscangus Pass Labs 9 27th January 2006 01:21 PM
Newbie building JFET Zen v8 summilux Pass Labs 12 26th January 2006 10:40 PM
Newbie at this speaker building! Please help! JiggaD369 Multi-Way 11 23rd June 2005 01:38 AM
Newbie building speaker box. Help. intelceleronman Multi-Way 14 29th October 2002 09:08 PM
Page generated in 0.11470 seconds (80.25% PHP - 19.75% MySQL) with 11 queries
