Crossover crackle
Crossover crackle
Old 2nd July 2017, 03:42 PM   #31
system7 is offline system7  United Kingdom
system7's Avatar
I think you might have a dry joint on one of the coils, or possibly a capacitor or resistor:
On the prototype I built I heard the tweeter crackle like clipping, in the pattern of "the lack of dithering". However, when switching the crossovers around the sound followed along to the other speaker. The one troublesome crossover also has some weird harmonics that sound like a damaged diaphragm.
You know you must scrape the enamel off coils wires and tin them well... they are tough as old boots and rarely fail. As are resistors. Capacitors are more fragile with excessive heat. The chocolate block connector is not the most reliable thing in the world either. FWIW, those spade or ring (what do you call them?... ) connectors sometimes don't make a great connection either. Tighten them well.
Best Regards from Steve in Portsmouth, UK.
Old 2nd July 2017, 04:05 PM   #32
scottjoplin is offline scottjoplin  Wales
scottjoplin's Avatar
Those are ring terminals, spade terminals look like.........er.......a spade
Woofer Assisted Wideband is the New Testament renounce the anachronistic acronym FAST
Old 2nd July 2017, 04:13 PM   #33
mondogenerator is offline mondogenerator  England
mondogenerator's Avatar
Default Just a thought
I've had a similar experience before and found it highly frustrating.
Try loosening the fixing screws around the tweeter faceplate by a turn or so.
My crackling issue was caused by over tightening these screw and distorting the tweeter frame....
Balancing the things I must do, with the things I'd like to do...This is a skill (or a luxury) amongst many that I do not possess.
Old 2nd July 2017, 04:20 PM   #34
picowallspeaker is offline picowallspeaker  Italy
picowallspeaker's Avatar
Originally Posted by system7 View Post
Tighten them well.
Take 'em off!
Everything
Just a thought: keep the tw well isolated too
Everything under and above heaven is in utter chaos
mare monstrum
Old 16th August 2017, 06:04 PM   #35
HumbleDeer is offline HumbleDeer  Belgium
HumbleDeer's Avatar
I'm actually aware of the enamel. I would've removed it if it weren't for Jantzen Audio helping out the true beginners that wouldn't know by pre-tinning the leads. Trust me on soldering. I'm an advanced electronics maker and breaker. Just not in audio-grade as far as electrical knowledge goes.
This can't be the case, as the tweeter's face plate is completely separated from the main frame.
I nailed it down though: The tweeter's voice coil gap has defects. Apparently I'm not the only one. The RS28-A is, supposedly, notorious for voice coil rubbing.
Old 16th August 2017, 07:56 PM   #36
sesebe is online now sesebe  Romania
So you find a defective tweeter?
Or just consider tweeter defective because other had problems with it ?
Old 16th August 2017, 08:11 PM   #37
HumbleDeer's Avatar
I consider it defective because I actually took Diaphragm A from Tweeter A and put it in tweeter B, and it still scratched. I hooked up my ND-series tweeters from something else and it went completely away.
I already am way past the switch-crossover-and-see-if-problem-switches stage
Old 16th August 2017, 08:42 PM   #38
I did not understand your test exactly but if you are convinced of this I do not want to change your belief
Old 16th August 2017, 08:43 PM   #39
HumbleDeer's Avatar
What I did:
Took out tweeters, used different tweeters: problem gone.
Conclusion: one of the original tweeters is damaged.
Crossover crackleHide this!Advertise here!
Subwoofer crackle cfaftw Subwoofers 0 25th November 2015 04:58 AM
Snap, Crackle, Pop! Superman541 Tubes / Valves 7 16th August 2015 08:34 PM
Crackle !! can't solve ?? titanchen68 Class D 29 7th May 2006 03:20 AM
Amp Crackle DoubleWammy Instruments and Amps 4 23rd April 2005 02:51 AM
