Do some tweeters intentionally have a peak at around 10KHz?
Old 30th June 2017, 03:37 PM   #1
andy2 is offline andy2  United States
Sin Bin
Default Do some tweeters intentionally have a peak at around 10KHz?
I don't know if this is true but some tweeters have a slight depress at around 3K - 7K, but then have a slight peak at around 10KHz. I think sibilance is in the 3K - 7K region. At around 10Khz, it's not sibilance but more like what audiophiles call "air". So I don't know if this is intentionally done to add an extra sense of "air" without increasing the sibilance. I am not sure I like this approach though since I think any intentionally emphasis in any freq. response would make the sound less natural.
Old 30th June 2017, 06:39 PM   #2
TBTL is offline TBTL  Germany
Interesting question. I cannot answer it, but I know this: many tweeters are 1" soft domes. Those have a resonance at their lower cutoff (~1 kHz) at which the dome moves as a rigid body. This can cause a bump at that frequency. Modes of the dome itself start at 6 kHz if I remember correctly, so one of these could cause a peak at 10 kHz. Those usually are well damped, but still one of them can show up in a graph. Furthermore, above ~5 kHz a 1" dome starts to beam, increasing the on axis sound level as those high frequencies are forced forward.
A broad bump at 1 kHz and a narrow one at 10 kHz somewhat matches your description.
Old 30th June 2017, 08:28 PM   #3
454Casull is offline 454Casull  Canada
Probably not. Are you possibly referring to diffraction artifacts?
Old 30th June 2017, 08:45 PM   #4
rongon is offline rongon  United States
rongon's Avatar
The Vifa / SEAS tweeters used in the 1990s Snell Acoustics speakers had a response peak in the vicinity of 10kHz. FWIW...
"Snell E/III, anechoic response on tweeter axis at 44" (black), corrected for microphone response, with individual responses of the tweeter (red), woofer (blue), and port (green), measured in the nearfield below 300Hz." (From a review in Stereophile Magazine)
Old 1st July 2017, 02:52 PM   #5
Lojzek is offline Lojzek  Croatia
Lojzek's Avatar
Broad bumps at 1 kHz are due to a higher Qts which in itself is not an issue if you know how to design HP filters. An example is SS D3004/604000. Standing waves at 10 kHz calculate to 1,7 cm so maybe not adequately stuffed rear chamber.
A good dialogue makes you feel like a changed person, not like you have won or lost the competition.
Old 1st July 2017, 02:55 PM   #6
HumbleDeer is offline HumbleDeer  Belgium
HumbleDeer's Avatar
I think 10K bumps might also induce some imaging-preferred effect. They're not good for monitors, however.
Do some tweeters intentionally have a peak at around 10KHz?Hide this!Advertise here!
Intentionally delayed reflections CabinetMakerRyan miniDSP 2 27th December 2015 12:35 AM
Intentionally Coloring the Sound soundwavesteve Multi-Way 21 5th July 2013 06:02 PM
Spect output peak to peak for 807 SE ul walter807 Tubes / Valves 2 1st December 2010 11:24 AM
Intentionally Unbalanced mixer? dlciii Car Audio 16 11th March 2009 04:39 AM
Intentionally Lossy Box ch83575 Multi-Way 1 25th February 2006 07:52 PM
