Realistic Optimus T-200
Old 3rd October 2006, 01:13 AM   #11
TomWaits is offline TomWaits  Canada
TomWaits's Avatar
Default T-200's
I could be wrong but I thought these had one woofer and a look-a-like passive radiator on the bottom? There was no port due to the radiator but I may be wrong because I'm going back to when I was like seven years old here! The T-200's were sold in the late seventies and were a success later superceded by the T-1200's in the early 1980's.
I'm a little dodgy on this?
Shawn.
Old 3rd October 2006, 01:27 AM   #12
TomWaits's Avatar
Default T-1200 better Image
Better pic. I have a bunch of Radioshack catalogs and flyers but my earliest copies are 1986.
Keep the T-200's and put some new drivers in them or blow them up, then put in new drivers.
Actually there is the possibility of putting new surround foam on the drivers and maintaining the orriginal set up. Perhaps replace the caps on the crossovers with new ones?
Do it for Dad!
Shawn.
Old 3rd October 2006, 01:33 AM   #13
TomWaits's Avatar
Default T-200
From the Net this is what your have? I'd rebuild them or repair them and keep them for my son to fix in 30 years.
Shawn.
Old 3rd October 2006, 04:21 AM   #14
elfranche is offline elfranche  Canada
elfranche's Avatar
I'd keep them too.
Old 3rd October 2006, 05:45 AM   #15
RandomTom is offline RandomTom  United States
Default Re: T-200
Shawn.
That's it! Mine are in a bit better shape - only missing a few bits of the surround.
I believe the passive radiator "improved" version came later. The second of the pair was purchased on close-out, and I suspect were the last full sized non-ported speakers they sold. (As a teenager I couldn't afford both when I wanted them...so I bought one and listened in mono for a year!) I don't have the manuals anymore, but they actually published the on-axis and, I believe, 30 degree off-axis frequency response for these things in it.
I'm not sure where the originator of this thread went, I jumped in after doing a search...I had the same question. These have always been mine, but too many years of apartment living led to their lack of use.
Old 3rd October 2006, 08:26 PM   #16
Dr.Faustus is offline Dr.Faustus  United States
Default Buy a re-foam kit
do-it-yourself REPAIR KIT ($50 for four)
I would definitely recommend buying a repair kit. Replacing the surround on a woofer isn't difficult, just take your time, follow the directions and don't rush the job. Finding replacement woofers with matching Thiele-Small parameters will be very difficult (if not impossible) and much more expensive.
There are a range of companies that will sell you a resonably priced woofer repair / refoam kit. Google around for "speaker repair kit" or "refoam kit" and you'll find many vendors to choose from.
If the old speakers sound good to you, re-furbish them and enjoy the sound.
FWIW,
Dr. Faustus.
Realistic Optimus T-200Hide this!Advertise here!
Optimus speakers mikejennens Multi-Way 2 3rd July 2009 01:00 AM
Realistic/Optimus Mach Two Tweeter nevdale Multi-Way 3 9th September 2008 04:14 PM
Realistic Optimus X-100 speakers Trebla Multi-Way 0 30th November 2006 12:05 PM
WTB: REALISTIC MINIMUS/Optimus 7 Speakers mrdon Swap Meet 0 28th May 2006 10:39 AM
Copyright ©1999-2017 diyAudio
