Old 25th March 2004, 05:13 PM   #1
Default Crossover wiring, common - ?
When wiring a crossover ( my first ), can all threee negative leads off of the speakers have a common terminal?
Or does everything have to follow the order of the schematic?
Old 25th March 2004, 06:02 PM   #2
Lionel is offline Lionel  France
Default Re: Crossover wiring, common - ?
Yes you can wire them to the same negative terminal.
More difficult and not necessary because controverted : the bi-wiring.
One terminal for the boomer.
One terminal for the tweeter (or tweeter + medium)
Old 25th March 2004, 06:44 PM   #3
So, theoretically, all points that are wired to the negative lead, could be wired to one common point?
I appreciate the help!
Old 25th March 2004, 07:36 PM   #4
Yes
I appreciate the help! [/B]
You're welcome
Old 26th March 2004, 06:22 AM   #5
lucpes is offline lucpes  Europe
Send a message via Yahoo to lucpes
I'd make sure that the point coincides with the back of the binding post, it will make woofer-mid-tweeter interference (due to woofer EMF or even a large np electrolytic which can spurt all kinds of garbage out) less possible.
Help w/crossover wiring babgrip Multi-Way 7 13th December 2008 07:00 AM
PTP Active Crossover Wiring paulhfx Multi-Way 3 22nd August 2005 01:35 AM
I need help wiring a simple crossover shadiedog87 Pass Labs 6 6th December 2003 03:03 PM
What are the common audible crossover points? dih1118 Multi-Way 2 22nd September 2003 09:12 PM
Common Source versus Common Drain output stages alaskanaudio Solid State 33 27th March 2003 02:04 PM
Page generated in 0.08646 seconds (71.71% PHP - 28.29% MySQL) with 10 queries
