Alpha 15A Upgrade in OB - diyAudio
Old 19th June 2017, 05:46 PM   #1
Default Alpha 15A Upgrade in OB
Have been running Alpha 15As in biamped OB for a few years. Wondering if there is a reasonable 12 or 15" upgrade to these. TIA
Old 19th June 2017, 07:54 PM   #2
DougL is offline DougL  United States
I have questions:
What's your Crossover point?
Are you looking for a Specific Qts?
What's your Budget?
What don't you like about the Alpha 15's?
Scienta sine ars nihil est - Science without Art is nothing. (Implies the converse as well)
Mater tua criceta fuit, et pater tuo redoluit bacarum sambucus
Old 19th June 2017, 09:11 PM   #3
Currently 200 Hz
Seems you want around 1.0 or greater in OB
>>What's your Budget?
$300-400 pair max?
They don't seem to have the best definition but I might just need more power and a lower xover point.
Old 20th June 2017, 08:32 AM   #4
Lojzek is offline Lojzek  Croatia
Lojzek's Avatar
Hi, I don't think it's necessary to exchange the woofer, rather if, then design philosophy, imo. This is the response difference between a sealed and OB driver loading, having in mind that I haven't simmed additional stuffing that would have reduced the Fb peaking. In case that your XO filter isn't optimized, you'd for sure note something wasn't as good as it might have been. Baffle step is factored in.
Mankind is created for eternity.
OB 2-way Alpha 15A with 27TDFC? etc grantnsw Multi-Way 12 10th June 2009 06:01 PM
Suggestions for HF for Alpha 15a OB? AudioGeek Full Range 2 26th January 2009 09:23 PM
OB FE126e with Dual Alpha 15a vanofmonks Full Range 2 21st April 2008 06:19 PM
fe167e and Alpha 15a OB arrived AudioGeek Full Range 14 10th April 2008 07:58 AM
Copyright 1999-2017 diyAudio
