Well that tweeter T35B needs a cap. Either internal or external but no way that a tweeter can run fullrange. So if it isnt damaged you should aim for a value that brings you near the recommended crossover point of 3.5kHz. I actually cross my T35 (same tweeter on the LT-15) a little higher. If you want i can check the value of my caps.
http://www.cieri.net/Documenti/Istruzioni/Electrovoice - Tweeter T35, T35B, T350.pdf
Recommended crossover was the x-36 for a standalone T35/T-35B
http://www.electrovoice.com/binary/X6_X8_X425_X825_X36_X336_X2635_Engineering_Data_Sheet.pdf
http://www.mcmlv.org/Archive/HiFi/ElectroVoice12TRXB.pdf
<snip>
Yes, Please!! And thank you!!
Ok sorry for the delay in response.
So original cap on my tweeter horn was 3uf
I replaced with a high quality sandwich of (0.47+0.52+0.52+0.01)=1.52uf
I started with just 0.47 and the small bypass 0.01uf and added untill i liked it. That's why I ended up with two units of .52. If i new i would stop at 1.5 i probably would have started and ended with a good 1.5uf cap from the start but i kept this sandwich because the money was spent. Trashing that and re-spending on a single 1.5 uf unit wasn't in the cards.
Paba
Paba
Thanks all for the replies, and especially you Paba for digging the info out of your speakers as I lnow they are not easy to open up.
I have taken my E-Vs out of service for now until I get the parts and pieces together, so far I do not think I did any damage to the tweeter, but want to play it safe.
Thanks again all!
Thanks again all!
