How to open E-V TRX12B speaker to change caps?
Old 24th June 2017, 04:38 AM   #21
nfafan is offline nfafan  United States
Well, thanks all for the replies. If nothing else, maybe the pics will help the next bloke who comes across a pair of 12TRXBs and wonders what is inside.
Old 26th June 2017, 03:08 AM   #22
paba is offline paba  Canada
Well that tweeter T35B needs a cap. Either internal or external but no way that a tweeter can run fullrange. So if it isnt damaged you should aim for a value that brings you near the recommended crossover point of 3.5kHz. I actually cross my T35 (same tweeter on the LT-15) a little higher. If you want i can check the value of my caps.
http://www.cieri.net/Documenti/Istru...5B,%20T350.pdf
Recommended crossover was the x-36 for a standalone T35/T-35B
http://www.electrovoice.com/binary/X...Data_Sheet.pdf
http://www.mcmlv.org/Archive/HiFi/El...oice12TRXB.pdf
Old 26th June 2017, 03:45 AM   #23
<snip>
Yes, Please!! And thank you!!
Old 4th July 2017, 01:57 AM   #24
Ok sorry for the delay in response.
So original cap on my tweeter horn was 3uf
I replaced with a high quality sandwich of (0.47+0.52+0.52+0.01)=1.52uf
I started with just 0.47 and the small bypass 0.01uf and added untill i liked it. That's why I ended up with two units of .52. If i new i would stop at 1.5 i probably would have started and ended with a good 1.5uf cap from the start but i kept this sandwich because the money was spent. Trashing that and re-spending on a single 1.5 uf unit wasn't in the cards.
Paba
Old 6th July 2017, 10:24 PM   #25
Thanks all for the replies, and especially you Paba for digging the info out of your speakers as I lnow they are not easy to open up.
I have taken my E-Vs out of service for now until I get the parts and pieces together, so far I do not think I did any damage to the tweeter, but want to play it safe.
Thanks again all!
How to open E-V TRX12B speaker to change caps?Hide this!Advertise here!
Forte model 2: worth to change caps? ad010685 Pass Labs 5 20th December 2017 08:11 PM
Behringer CX2300 replace caps (values change) Trileru Analog Line Level 57 25th July 2015 11:08 AM
PSU Smoothing caps change, Now 1 of the internal fuses blows on power up, help :-o Deaf Cat Power Supplies 6 11th April 2015 10:45 AM
Any reason not to change Tantalum caps for aluminium electrolytics Puggie Parts 14 6th December 2005 01:15 PM
Phono stage and caps - change? Zombie Solid State 50 31st August 2003 09:43 PM
