Custom Concrete Speaker Cabinets
Old 15th June 2017, 04:41 PM   #11
chrisb is offline chrisb
Originally Posted by badman View Post
DIY speaker builders, I suspect, have higher than average education levels and incomes. I don't disagree with your conclusion (not a great market), but in my experience most DIYers are in their 40s-50s and are reasonably well-to-do. The tools, time, etc, are not as accessible to people of low income, naturally, there are some exceptions.
Hmm, if a poll on income and edumatcation levels were politically correct, I think you'd find the results interesting
like my mind, this space intentionally blank
Old 15th June 2017, 05:00 PM   #12
Badge is offline Badge  United States
I did a front baffle in a cement mix. Props to anyone who can cast in driver openings, and maintain hardness so it does not crack or break.
The freaks stick together, they are a tight old crew
Old 15th June 2017, 06:37 PM   #13
CharlieLaub is offline CharlieLaub  United States
So perhaps the best approach is a run of small-ish (10 liter?) cabinets that are too small to ring much and not so heavy that shipping costs are unaffordable. Then if people want something custom/larger/oddly-shaped that can be done on an individual basis. The guy can fabricate more or less any shape that you can make with a pour process and a mold. How about a sphere? Can do. Curved baffles, sides, etc.? Can do. But these more complex options would be much more expensive and done on a custom basis. On the other hand, the production box can have curves and something that you just cannot do very easily in wood might be nice to set it apart. For example a racetrack-oval shape.
I don't think that including a few threaded inserts (e.g. to hold on a baffle) will represent a problem. DIYers can usually prepare their own baffles. On the other hand a rebated baffle out of terrazzo that is customized to a particular set of drivers is getting into the low volume custom work unless there is a group buy arranged or something like that.
Visit my Audio Web Page <<--CLICK TO LEARN MORE-->> Get my LADSPA plugins
Old 15th June 2017, 06:43 PM   #14
FWIW, I'd imagine the time and cost to fabricate molds and pour custom rebated baffles could be greater than CNC machining from billet aluminum?
Old 15th June 2017, 06:49 PM   #15
jcx is offline jcx  United States
not sure the basic idea of (polymer?) concrete baffles or the demand
but molds for "2.5 D" ~ flat stuff is way easy today with large CNC gantry routers at maker spaces or as services from the many individuals who have them in home wood shops
Old 15th June 2017, 06:59 PM   #16
Molds are made from foam and fiberglass. Remember, the mold is then used to make many, many identical items. Machining an ALU block makes one.
Old 15th June 2017, 07:04 PM   #17
Remember this is not really about the material (concrete) being better than aluminum or whatever. It's more about the amazingly beautiful surface finish of the terrazzo material and the fact that a mold can be used to consistently reproduce the shape. Also, while the shape would be fixed by the mold itself, the color of the cement and inlay can be varied greatly to the preference of the end user, for instance to match decor or to give it a certain look.
Old 15th June 2017, 09:01 PM   #18
Another option would be to make a DIY copy or at least take design cues from a famous speaker and do some key parts in the terrazzo concrete.
How about something based on the B&W 801?
The concrete part could be the ball and its plinth (slanted top of woofer cabinet) that contain the midrange and tweeter. The DIYer would build the rest out of wood.
An 801 inspired DIY speaker using current drivers would be a pretty cool project!
Old 17th June 2017, 04:06 PM   #19
Pallas is offline Pallas  Pakistan
What about an egg (think Waveform) that could be used as a mini monitor or the "head" of a 3-way?
Serious Audio Blog
Old 17th June 2017, 04:51 PM   #20
HeyBill is offline HeyBill  United States
A pure open baffle to start might prime the pump.
What's that smell?
Custom Concrete Speaker CabinetsHide this!Advertise here!
Prebuilt or custom speaker cabinets? midside Multi-Way 1 12th June 2017 02:44 AM
Concrete Cabinets sunbeamgls Multi-Way 186 9th April 2017 02:25 AM
Huge Concrete speaker cabinets in foundation Graydon Subwoofers 19 3rd November 2016 08:18 PM
FS Morel drivers, custom CNC machined aluminum cabinets, Dayton cabinets Bronson_k Swap Meet 12 12th July 2015 08:39 PM
Custom made speaker cabinets (no drivers) maurycy Swap Meet 0 23rd May 2006 09:03 PM
