Home Theater Speakers
Old 13th September 2017, 02:36 AM   #21
Brett is offline Brett
Brett's Avatar
Originally Posted by Maverick2020 View Post
The tweeter is sooo asking to be smashed in by a kid haha. "Oooooo look its a button!"
There are things called grilles.
Old 13th September 2017, 03:02 AM   #22
eriksquires is offline eriksquires  United States
eriksquires's Avatar
The phase plug on a ring radiator does not move, and on the XT series are quite sturdy.
Best,
E
All of my successes and failures can be explained by my attempts at getting a girlfriend. All of them.
Old 13th September 2017, 06:44 AM   #23
Mrcloc is offline Mrcloc  South Africa
This is fantastic info, coincidentally. I'm going to be using that XT Peerless as soon as I can get hold of them.
Old 13th September 2017, 07:57 PM   #24
Glad to be of service, Mrcloc, that tweet has it's fans.
A recent discussion here compared it to their ScanSpeak equivalent, and I think the consensus was the SS was a little better made with a little less distortion and a little more output.
Best,
E
Old 14th September 2017, 07:07 AM   #25
Fantastic, thanks. I'm buying from Parts Express, but the SS isn't available there. I'll make up a cart at Madisound and compare the costs, because I believe I can get all my stuff there, as well as the SS. But I like the look of the Peerless because I'm using a Visaton W170S, so the 5-screw drill pattern matches well.
ETA: I see the SS also has 5 holes, but it's almost double the price, and for that reason, I'm out.
Old 14th September 2017, 07:13 AM   #26
Be careful that you don't substitute my measurements with either the SS or another version of the XT25. The measurements in the LM-1/LM-1C are for the XT25BG only.
If you use a smoother mid-woofer you can get away with the single-magnet version of either brand. The FaitalPRO 5FE120 for instance will get you up into a 3-4kHz crossover area. Also has better power handling than the Peerless I used.
Best,
E
Old 14th September 2017, 07:25 AM   #27
The one I'm going with is the XT25BG60-04. I need to cross it at 1.8 - 2 kHz. Unfortunately I have limited resources, and built speakers which only need the tweeters to be upgraded. They're already excellent, but they'll be better with better tweeters.
As for mid-woofers, what do you think of the Dayton Audio RS150P? I have my eye on that for any future builds.
Old 14th September 2017, 04:26 PM   #28
Oh, sorry Mrcloc, if you need tweets for an upgrade, the XT25BG60s are the way to go.
No idea about DA woofers, but I'm sure others have opinions.
Best,
E
Home Theater SpeakersHide this!Advertise here!
Mismatched speakers in home theater? Doggyboy Multi-Way 1 4th May 2013 09:59 AM
Need some help: home theater speakers kazoo Full Range 15 14th February 2011 12:31 PM
Best $800 on home theater speakers? CZ Eddie Multi-Way 9 9th December 2003 09:58 PM
