I want to design a speaker to produce high SPLs (120db+) at midbass frequencies (40-60Hz+). I have read about TLs, Dipoles and Horns, and I would guess, from what I have read, that a horn would be the most efficient, and therefore would produce the greatest SPL.
My question is, simply put, which method, (including monopoles, dipoles, TLs, horns and other suggestions), would produce the highest SPL? I realise the driver, power consumption and size would come into this decision, but I am simply looking for the cheapest route to take. Answers appreciated Matthew
If it aint broke, don't fix it. If it is broke, fix it. If you can't fix it, take it apart and see how it "worked". |
#2 |
A horn would need to be massive to work at 40 to 60hz.
A big pro audio driver reflexed in a big box is the way to go. But no route is cheap for 120dB at 50Hz. |
#3 | |
maybe a higher frequency, the SPL is the important thing.
#4 |
IB sub with 4- 15"ers and a couple hundred watts per driver would do that pretty easily
"The appreciation of music is subjective.The reproduction of music isn't."-Bill Dudleston |
#5 |
The old Radio Shack (Not Pioneer) 8" full-range speakers with the whizzers are capable of extension from 45hz to 15khz, and they're efficient. Enough of them in a box could be very loud.
I can't be 100% sure, but I think you can find the same driver here: http://www.partsexpress.com/pe/pshow...number=300-010 Failing that, there are a couple of PA target drivers in the 5-10" range in there, that aren't really very expensive... I don't have the numbers on hand tho. If you want 'em, I can find 'em. |
#6 |
so a monopole would be more efficient than a horn?
#7 | |
Sreten's advice is what you need to do. An Fc=40Hz folded horn using a 12" driver could probably be done in 300L if you can live with that. Other option is direct radiator pro sound high efficiency 18" drivers. Plenty of output over 120db from 40Hz and up in a vented box. JBL 2241 and 2242 are two excellent options for this. What is your application? PA or home hifi? |
#8 |
definately horn
have a look at the latest issue of AudioXpress for Bill Fiztmaurice's Tuba 24 article. 24inches cubed, 1 10" woofer (Carvin PS-10 or Eminence Beta-10) have a look at this: http://hometown.aol.com/fitzmauricew...age/photo.html |
#9 | |
i just want to be able to play music loud, not for any specific use. 300L isnt that large for a basshorn. any examples of drivers for a horn? beyond the LAB12.
#10 |
You could use the Volt RV4504, this is an 18" unit
and should work OK in 150 L reflex enclosure (-3db at 40Hz) However, it is expensive. see: www.voltloudspeakers.co.uk |
| How to achieve very high damping factor with LM3886 | rhythmdiy | Chip Amps | 15 | 21st October 2007 08:13 AM |
| Extending a high frequency horn to achieve a lower cutoff | MaVo | Multi-Way | 6 | 7th September 2007 03:55 PM |
| high efficiency 10-12" midbass drivers | Puggie | Multi-Way | 3 | 19th August 2005 03:35 PM |
| Looking for a high-end 8"-10" (20cm) midbass | Vortex | Multi-Way | 25 | 31st January 2004 09:03 PM |
| Page generated in 0.11958 seconds (80.56% PHP - 19.44% MySQL) with 11 queries |
