Old 24th March 2004, 02:18 PM   #1
Banned
Send a message via MSN to SkinnyBoy
Default What on earth would you call this?? (see pic) horn, snailshell, TL???
ok... there's some DISCUSSION going on between myself and the dude over there at Powered 4 Sound (ya know, the 6.5inch woofers sounding like 12inch subs)
anyway.... I am pretty sure the snailshells are horns of some type, but he denys it.... thats not the point however...
I asked him what this was: (woofer mounts where the RED line is)
and he told me it was a transmission line... hmm.. ok... strange... what are your thoughts?? and what do you think of the snail shells?? horns, TL's or some other made up term I can't remember that I'm pretty sure the guy made up on the spot... lol
here are some home made snailshells... although one person actually called it a transmission line...
so my fuzzy little friends... whats the go??
Old 24th March 2004, 03:06 PM   #2
they are both forms of tapered resonant 1/4 wave lines.
(TL's to most people)
The 1st seems to be wasting some enclosure volume.
The second has a strange CSA profile.
sreten.
Old 24th March 2004, 03:14 PM   #3
Ropie is offline Ropie  United Kingdom
Ropie's Avatar
I agree, they are TLs. The closed off area at the front of the section drawing could probably hold a small tweeter.
Old 24th March 2004, 04:40 PM   #4
GM is offline GM  United States
GM's Avatar
If it has a positive taper with no constriction at its terminus, then it's technically a horn. Since this one has a low pass filter (constricted throat) in series with the driver, which also radiates into free space, it's a (low) compression loaded backhorn.
WRT the DIY pipes, it's hard to tell what the 2nd and third expansion rate is, but I would classify it as a hybrid (low) compression backhorn since it has a constricted throat, expanding first section, another constricted throat, then either two constant CSA expansions or very low positive CSA ones. Reminds me of hi-perf muffler designs.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 24th March 2004, 04:43 PM   #5
Mudge is offline Mudge  United Kingdom
They're not classic TLs or even tapered TLs. I would say due to the necking of the line they would be closer to TQWTs than classic TLs.
Mark
The king of all that is evil has left the building
Old 24th March 2004, 05:01 PM   #6
BAM is offline BAM
Send a message via AIM to BAM
Some Bose engineer is probably kicking himself...
Or perhaps the designer is ex-Bose
If it's a horn, it has some kind of huge compression chamber, and there is a straight taper right at the beginning of the horn but it doesn't continue for the other two segments. That third segment is a lot bigger than the second.
Since a horn is just an acoustic impedance coupler, that flared section could have some sort of coupling going on to the second segment of the pipe which then is slot-loaded by the third?
Maybe the size of that terminus thing is the same as the width that the first taper is opened to before it interfaces with the second segment of the line.
Here's a picture of a concept design I saw on the Powered4Sound message board looks really stupid. The guy (not the P4S guy but someone else) explained that it lets the sound go out but doesn't let it come back in.
Old 24th March 2004, 05:31 PM   #7
Timn8ter's Avatar
So once the driver pumps all the air out a vacuum remains?
Old 24th March 2004, 05:35 PM   #8
kan3 is offline kan3  United States
doesn't stop there, a black hole is formed and eventually sucks the box and everything in the vacinity into it
probably why you don't see to many people using them
Old 24th March 2004, 05:54 PM   #9
Send a message via MSN to officeboy
Interesting, that looks quite a bit like a lowpass filter.
Old 24th March 2004, 05:59 PM   #10
Bricolo is offline Bricolo  France
Bricolo's Avatar
what's a CSA.
what do you call this stuff. neutron7 Everything Else 4 8th August 2007 09:16 PM
I don't even know what to call this- Conrad Hoffman Everything Else 16 24th June 2007 04:11 PM
call me embarassed! shepperd Class D 2 6th February 2007 09:56 PM
Call me stupid, but..... LNeilB2 Multi-Way 7 28th January 2003 05:55 PM
Page generated in 0.11884 seconds (78.67% PHP - 21.33% MySQL) with 11 queries
