Won Horns @ LSAF - help me do something worthy with them
Old 31st May 2017, 04:25 PM   #11
EndersShadow is offline EndersShadow
Originally Posted by Pano View Post
I was looking at the measurements of the 2ft box with the Delta Pro 12. Mid-band it's 95dB at 2.83V, which is impressive. If you take 95dB as reference, then it does play down to 40H, then rolls off fast. The bass bump above that will sound nice, but will be dependent on room gain. That's darn good for that size speaker. It's not small, but considering my old rig had 11 cu ft bass boxes (external), it's not a monster.
Yeah, I was hoping to get away with a 1.5- 1.75 cubic foot box, but then I'd have to go with a 8" driver and that would likely be hard to find a high sensitivity one that wasnt an arm and a leg that would work in that type of design. I'm ok with a 2 cubic foot box as thats the smallest I think I can really get into without getting a lot of rolloff as you drop below 60hz.
I'm totally fine with significant rolloff at 40hz as I plan to use my sub with these, but I'd like the "option" of running them as pure stereo speakers and still be able to get a fair amount of the normal frequency bandwidth from most music. I dont listen to pipe organs ever, though I enjoy a fair amount of dubstep and electronic music, which digs deeper than these will go, hence the sub addition.
I'm anticipating running a highpass around 35 on the Definimax, not sure about the Delta 10, I'd have to look at the graphs. If you have the WinISD file created already, anyway you could attach it here? I'm not so much good with inputting the numbers in the right sequence to get them to not error out.
Also since this setup will be 2m or less from you when listening, I doubt I will even get it above 90 db.
For my sim's I'm using 100 watts as the input signal as I dont anticipate using an amp with more than that anytime soon. I'm going to run them off my Anthem which is 100 wpc @ 8 ohm x 2 channels per spec, so thats why I choose 100 watts for modeling.
Originally Posted by djn View Post
All the woofs mentioned will work well. If you have two amps, go with the MiniDSP. You can tweak the crossover parameters to fit your room much more persisly then messing with a passive. With those woofs and horn, going digital or SS on the woof and a small SET tube amp on the horn would be the nuts!!!
Yeah I thought of that, it just starts getting more complicated than I was hoping to go, but I am well aware of the benefits. With the MiniDSP as the crossover I would have to do a lot of work to get that right before running the Anthem ARC which I've found to do a STELLAR job at EQ. It would also basically make the amp channels in the Anthem a moot point as I couldn't use them.
Right now I JUST have the Anthem MRX-500 to work with so I could potentially use the marketed bi-amp feature to drive each driver independently, but that starts to get tricky I think....
Old 31st May 2017, 04:46 PM   #12
kevinkr's Avatar
I was at LSAF, you definitely have good luck in winning those horns! His room was definitely one of the better sounding rooms at the show.
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 31st May 2017, 04:53 PM   #13
I failed to make it to his room before they packed up unfortunately.
I enjoyed JWM, The Black Hole, Stereo Clarity and Blowtorch's rooms immensely. Each for a different reason.
I also really liked Skips room (Audio Thesis). Douglas Connections room was pretty cool too and I enjoyed seeing all the bling he brought with him. And those small bookies in the GR Research room blew me away for a desktop setup. Those things were awesome.
There were a bunch of us from another forum floating around and most of us agreed we will be back next year.
Old 31st May 2017, 04:56 PM   #14
kevinkr's Avatar
I liked the JWM room and Austin Audio as well as a couple of others. I bought an Ortofon Windfeld cartridge and a head shell from JWM at the end of the show.
I plan to be back next year, maybe even exhibit some gear.
Old 31st May 2017, 07:50 PM   #15
Pano is offline Pano  United States
Pano's Avatar
If you listen to Dubstep and electronic music then a sub is a no brainier. In those genres, the subwoofer is used as a musical instrument. Listening to more "normal" music, a solid 40Hz will be plenty satisfactory.
I've attached 2 WinISD files zipped to get you started.The Delta 12A and a Dayton pro 12 that should play as deep in a slightly smaller box, but at ~3dB less efficient. I hope they have the driver parameters included.
Take the Speaker Voltage Test!
Old 31st May 2017, 11:39 PM   #16
They extract as .wid files not .wpr which are what all my other WinISD files show as.
Am I missing something?
Old 1st June 2017, 12:30 AM   #17
Pano's Avatar
Which version do you have?
Old 1st June 2017, 12:33 AM   #18
I think WinISD Pro 0.7.0.900
Old 1st June 2017, 12:35 AM   #19
Pano's Avatar
It won't open the older files?
EDIT. I can't get that version to run properly on Windoze 10.
Old 1st June 2017, 12:45 AM   #20
Weird, I'm running it on Windows 10 with no problems...
Try this version: http://www.linearteam.org/download/winisd-07x.exe
Won Horns @ LSAF - help me do something worthy with themHide this!Advertise here!
What I am taking to LSAF Bob Brines Full Range 69 28th June 2016 07:21 PM
Are these caps worthy of consideration ? hitsware Parts 18 25th April 2016 12:32 PM
The future of Lone Star Audio Fest (LSAF) pmillett Clubs & Events 110 13th April 2015 12:11 AM
LSAF is TOMORROW! Bob Brines Full Range 12 23rd June 2009 05:23 AM
Zen-worthy EQ? Michael Rothacher Pass Labs 11 31st August 2002 05:48 PM
Copyright ©1999-2017 diyAudio
