HiVi F6 project
HiVi F6 project
Old 27th December 2017, 08:25 PM   #21
troystg is offline troystg  United States
troystg's Avatar
This is how my daughter brought them back from college. ..
If you are still making a speaker with your drivers you can have these enclosures and xo's.
The speakers sounded FANTASTIC when I gave them to her with new drivers.20171227_150926.jpg20171227_151024.jpg20171227_151029.jpg
Troy
Thinking positive doesn't make things better, it makes you a better person.
Old 25th January 2018, 11:24 AM   #22
troystg's Avatar
I ordered new drivers and repaired the speakers. They sound good again (even before the woofers break in) and will be in a dedicated bedroom system. 20180124_182209.jpg
Troy
Old 10th August 2018, 11:38 AM   #23
Rakeem is offline Rakeem
Hello everybody, i am finally ready with my hi-vi project and i am fully satisfied, i didn't expected such a bass and sound clarity, the midrange is excellent, for the price i can want nothing more The tweeter is hivi-Q1R, the clear volume is around 16l. and 2 ports monacore br45. The only thing is that F6 moves too much when the volume is higher, maybe is something with the box volume or wool(4sm).
File Type: jpg thumbnail_WP_20180603_20_55_48_Pro.jpg (137.7 KB, 45 views)
Old 10th August 2018, 01:54 PM   #24
TMM is offline TMM  Australia
Send a message via AIM to TMM
Is this using the same enclosure specs as your original post? If so, the reason is that your tuning is too high. Under Fb, the woofer will unload as the port becomes a literal 'hole in the box'. Extend the length of the ports with some additional pipe, or block one of the ports.
Old 10th August 2018, 04:22 PM   #25
I am not sure where exactly is Fb, but around 50hz the cone excursion is less. The ports are with trumpet shape and can do nothing with the length, i can put some foam in one of the ports or maybe more wool, but too much wool can reflect negative on the higher frequencies. I am not sure if the lower Fb is good idea for bookshelf speakers, isn't the 50hz good for this type of speakers?
HiVi F6 projectHide this!Advertise here!
FS: HiVi F6 6" midwoofers NIB cbrunhaver Swap Meet 0 15th February 2014 04:22 PM
Looking for project MTM (would like to use HIV VI F6's...) fazman Full Range 2 14th January 2014 11:36 PM
FS: Lot of HiVi F6 Woofers and Dayton PT2C-8 planar tweeters Virpz Swap Meet 5 31st December 2013 11:12 AM
HiVi F6 6" Bass/Midrange drivers for sale (brand new) FraggleRock Swap Meet 12 15th November 2013 01:47 AM
Help with HiVi F6 in a 2-Way GOR3 Multi-Way 3 10th July 2013 12:15 PM
