(Super)Tweeter for W5-2106 full-range - diyAudio
Old 16th May 2017, 01:05 PM   #1
Default (Super)Tweeter for W5-2106 full-range
I have a TL speaker with Tang Band W5-2106 full-range and thinking about either converting it to a standard 2-way or just add a helper super-tweeter since there's something missing at the top end
The main problem is that I can only do a surface-mount so the only solution I see is to make a custom thin front plate for a tweeter. One of the candidates is Dayton Audio AMT Mini-8, with either first-order high-pass or a proper cross-over at 5KHz.
Old 16th May 2017, 04:22 PM   #2
scottjoplin's Avatar
Hi. The published high frequency response of the Tang Band looks very good, are you able to measure it to see in reality how it is performing?
What came first, the music or the misery? Nick Hornby https://www.youtube.com/watch?v=nSlleE9s9gI
Old 16th May 2017, 06:27 PM   #3
GDO is offline GDO
GDO's Avatar
Originally Posted by scottjoplin View Post
The published high frequency response of the Tang Band looks very good...
Mmm, for me no good: too shy above 2khz... Same size Jordans JX92 or Eikona have a much more agressively rising on axis response.
All TB i have used don't rise with the right slope: too shy and dull...Good for midrangers, bad for full rangers...
“Europe en marche? From so much thinking, his brain dried up and he went completely out of his mind.” M.de C.S.
https://www.youtube.com/watch?v=ROtte5cDJ08
Old 16th May 2017, 06:30 PM   #4
Gotcha, I was only going by this https://www.oaudio.de/en/Loudspeaker...e-speaker.html
Old 16th May 2017, 06:40 PM   #5
GDO is offline GDO
GDO's Avatar
Same page i visited...
Like this one much better: though some would say it looks weird, others will find polite sounding, some even too polite...
Old 16th May 2017, 06:46 PM   #6
Ha, that would probably suit me due to hearing loss..
Old 16th May 2017, 06:58 PM   #7
GDO is offline GDO
GDO's Avatar
And this one to me?
Old 16th May 2017, 07:11 PM   #8
Well, the HF does not have any kind of fall off and off-axis response is quite good. But something is missing compared to Alpair 7.3. Both speakers have active FR and phase correction by using DRC-FIR.
Old 16th May 2017, 07:23 PM   #9
GDO is offline GDO
GDO's Avatar
May be you might show some measurements with and without eq...
Btw, eq cannot fix directivity issues, and not all 4'/5' drivers behave the same, cone profiles also matter, etc...
Anyway DRC should help...
Old 16th May 2017, 08:30 PM   #10
GDO is offline GDO
GDO's Avatar
Don't know what good means by your standards, but good measurements and bad sound make no sense by mine...
Btw, the Alpair-7 looks good, meaning good rising response, the TB dont, too shy...
PD: Another question is that manufacturers are too shy to publish curves with an alarmingly rising trend: customers have no idea that it's a good feature for a full ranger and don't buy. Lowther and other wise guys, FR specialists, don't publish curves, or carefully photoshop them...
Tang-Band W5-2143 5" Full-range JoeHollis Full Range 14 30th January 2017 11:16 PM
FS: Fostex FE208EZ 8" Full range, T90A Super Tweeter leecc73 Swap Meet 0 4th September 2016 01:36 PM
Alnico Instrumental Speakers+Super Tweeter as an Option for very expensive Full-Range tiefbassuebertr Full Range 55 5th April 2016 12:26 PM
Adding a super tweeter to a full range portreathbeach Multi-Way 111 29th December 2014 01:39 AM
Tang Band W5-1611SA 5" Full Range Driver Bart Oetken Swap Meet 4 10th July 2012 07:22 PM
Copyright ©1999-2017 diyAudio
