Xover frequency recommendation between a 4in driver to 8in. driver
Old 22nd April 2017, 01:56 PM   #1
andy2 is offline andy2  United States
Sin Bin
Default Xover frequency recommendation between a 4in driver to 8in. driver
I will be building a pair of speakers that will be similar to Troels "Illuminator-4"
Illuminator-4
but instead of the 6.5in. mid range driver, I plan to use only a 4in. driver to improve the upper mid range dispersion. The cabinet will be almost the exact dimensions as his speakers. In his speakers, he designed the xover at around 200Hz between the 6.5in. and 8in. , but that may be a little too low for a 4in. driver. Troels being a fundamentalist when it comes to sound so he thinks the lower point xover is more important than the upper mid range. His solution is to add an extra 4in. driver with his "Illuminator-5" Illuminator-5
but to me it may have an extra driver too many and I am not sure about how to integrate the sound with all those drivers.
So my question if I were to use a 4in. driver, given the cabinet above, which is a good xover point between a 4in. to a 8in. driver? Should I use a 5in. driver instead?
Thanks.
Old 22nd April 2017, 02:20 PM   #2
Face is offline Face  United States
Face's Avatar
Cross at battle step, which off the top of my head, would be around 400hz with those cabinet dimensions.
Sent from my SM-G935V using Tapatalk
"He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
Old 22nd April 2017, 10:40 PM   #3
AllenB is offline AllenB  Australia
The 200Hz region is underrated IMO. Here is where you find the tactile feel, vocalists bumping their chin on the mic, footsteps and venue cues, breath sounds. In fact, there isn't any part of the spectrum you can annihilate and expect a good result IMO, only the tolerance varies.
Xover frequency recommendation between a 4in driver to 8in. driverHide this!Advertise here!
Need driver recommendation for 4L or less! nbriles2000 Full Range 17 13th June 2014 06:36 PM
Driver recommendation please jaybird Subwoofers 2 26th February 2009 11:40 AM
2.5" driver recommendation nanl2053 Multi-Way 26 25th February 2007 05:15 PM
Recommendation for sub driver UK DNRC Subwoofers 46 22nd January 2004 01:38 AM
Best 3 or 4in low/mid driver martioz Multi-Way 9 11th January 2003 08:19 AM
