How to determine the Crossover Frequency - diyAudio
Old 15th April 2017, 09:50 AM   #1
Desturo is offline Desturo  Germany
Default How to determine the Crossover Frequency
Hello everyone,
I just planned my first speaker build. Its a stereo stetup with a woofer and a tweeter on each side. The drivers I want to use are:
Tweeter: ND16FA-6 6 Ohm 3.5kHz-27kHz
Woofer: RS75-4 4 Ohm 170Hz-20kHz
The amp I am planning to use is the LEPY LP-VS3 with 2x25W.
Now I need to calculate the values for the inductors and Capacitors. I tried to use the calculator on this site: https://www.diyaudioandvideo.com/Cal...akerCrossover/
but it asks for the Crossover Frequenzy. So How do I get the Crossover Frequenzy for my Speakers.
Nico
Old 15th April 2017, 10:31 AM   #2
Just changed the Amp I want to use now I am considering the DTA-2
Old 15th April 2017, 10:47 AM   #3
Scott L is offline Scott L  United States
Hope this helps:
Resources
Old 15th April 2017, 11:46 AM   #4
Originally Posted by Desturo View Post
Hello everyone,
Nico
Look at the frequency response of the two bare units.
Find a frequency range for each. See what the two units look like in the range that overlaps. Decide on a suitable crossover frequency that minimises the worst of the frequency response anomalies in that overlap range.
Now using that frequency, calculate the basic filter components for the low pass 4ohms bass/mid driver.
Using the same frequency, calculate the basic filter components for the high pass 6ohms treble driver.
Note you MUST use a mixture of 4ohms components in one filter and 6ohms components in the other filter.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 15th April 2017, 11:59 AM   #5
Where can I calculate those values? Can I use the calculator wich I linked in the original post? And if I can which order should I take.
And I sattled for a Crossover frequency of 8.5kHz will this work?
Old 15th April 2017, 12:19 PM   #6
Flaesh is offline Flaesh  Russian Federation
Flaesh's Avatar
You can download FRD/ZMA Data Files for Daytons and use Xsim crossover design and simulation program..
flesh flash flush
Old 15th April 2017, 12:23 PM   #7
I have never designed a passive crossover.
I guess any of those roll-off cirves would suit. I would try a 2pole L-R as a first stab at something.
Your 8k5Hz seems very high.
Can your Bass/Mid even reach 8k5Hz?
How well does it reproduce to an octave above your 8k5Hz?
Even a 2pole Butterworth will pass a large amount of energy to the bass/mid in the octave above the theoretical cross-over frequency.
regards Andrew T.
Old 15th April 2017, 12:49 PM   #8
I downloaded Xsim but to use it I need the values for the inductors and capacitors wich I want to calculate.
Old 15th April 2017, 12:53 PM   #9
Yes it can. On the spec sheet it says it can reach to 20kHz.
And I dont really understand what you mean with reproducing an octave above 8.5kHz because I'm very new to this topic and don't know very much about it.
Old 15th April 2017, 03:36 PM   #10
Overthought my desicion and went with 3kHz Corssover Frequenzy
Please help me determine what driver this is. Forsman Subwoofers 3 11th September 2009 07:48 AM
Determine crossover frequency of existing XO focal7C Parts 1 26th May 2008 09:07 AM
How to determine crossover frequency? maurycy Multi-Way 2 7th January 2006 03:29 PM
How to determine Q from a graph? JoeBob Parts 4 13th November 2004 04:12 AM
How do I determine what this Transformer is? wotan2525 Solid State 5 21st March 2003 05:34 PM
Copyright ©1999-2017 diyAudio
