Hi, I'm building a vifa tower. Dimensions are 38"X10"X12.5".
I'm using 3/4 MDF and 3 internal shelf braces. I intend to use titebond wood glue. Should I also use screws? This is my first project and my searches see to get conflicting opinions. Thanks, Tony
Tony |
#2 |
Use glue and clamps. Don't screw anything in MDF, it sucks...
#3 |
Glue and clamps. It should be a little easier without the screws.
Thanks, Tony
Tony |
#4 |
I use heavy staples myself.
#5 |
If you do not have access to good clamps, predrill the panels (and make sure you countersink the screws). Use glue as well, something like tightbond, or similar.
Once the glue is set you could remove the screws, and fill them. There are MDF specific screws that have a coarse thread. |
#6 |
Always more troubles...Some people use airguns with slim nails, it's up to you...
#7 | |
Screws do not any any strength to the box. If you want it stronger use corner cleats. Like this.... |
#8 | |
#9 |
There's a technique that I've used that turned out OK that I'm sure I will use again. I'm just throwing it out for you to consider.
You need a plug cutter and a Forstner bit of the same size, 5/8" in my case. Predrill all hole locations with the Forstner bit to a shallow depth. Assemble cabinet conventionally with glue and screws. Allow to dry. Back out all screws. Cut plugs out of same material used to build cabinet. Glue plugs into screw holes. Allow to dry. Cut plugs flush and continue with finish work. What I like about it is that you avoid the need to buy a large number of clamps, yet by backing out the screws you can do some edge work such as large radius roundovers that you could not otherwise as the screws would interfere.
Aerodynamics are for people who can't build engines. Enzo Ferrari |
#10 | ||
Speakerholic
Brad nailing can be done on the inside of the cabinet. Basically used as clamps to hold the glued cleats. Cal |
| 2 quick SI questions | Decker | Class D | 2 | 26th November 2007 11:30 PM |
| 2 quick questions | JPeitzman | Chip Amps | 7 | 22nd July 2007 05:27 PM |
| 2 quick questions | Lowjacker | Car Audio | 3 | 8th July 2006 03:32 AM |
| Quick woodworking cabinet question.. | Skitch72 | Multi-Way | 7 | 18th January 2006 06:15 PM |
| quick questions | theChris | Multi-Way | 0 | 12th February 2003 04:54 AM |
| Page generated in 0.12470 seconds (78.25% PHP - 21.75% MySQL) with 11 queries |
