#11 |
>Exactly what physical effect do you think causes Vline to have any relation to Vas? If you build a 100m line with the appropriate CSA, then it will have the same Vline as one of 4xSd, but I guarrantee that the behaviour of the driver will be somewhat different.
>Vline is irrelevant, there are two parameters, one is the restorative force on a driver, which is a function of the impedance of the line, which is harder to calculate when the line is stuffed and the other is the frequency of the 1st standing wave in the line. >If the flow impedance of the stuffed line is 40x that of the empty line, then of course the CSA of the line should be 4x Sd, if the line impedance, as determined by the TS parameters (by a rather complex set of equations as yet) requires an unstuffed line of CSA 1/10 Sd. ==== Being a resonant device, a driver wants to 'feel' a certain amount of compliance, which is defined by its Vas. For it to 'feel' a ~equal amount of acoustic mass loading on both sides of it ('free space') requires the rear cab, be it sealed, vented, or pipe, to have a Vb of 4-10x Vas to be 'close enough' fo a typical HIFI app, not CSA = 1/10, or Sd, even if you make up the difference in Vb by increasing its length beyond that required to damp its Fs impedance spike. Sd, not Vas, is totally irrelevant WRT CSA until the CSA = <Sd. Some of the newer sub drivers have such a low Vas and Fs that the pipe is too small to fit the driver without an adapter. Otherwise, Sd is only relevant as being one of the components that defines Vas. MJK chose to use Sd as a convenient way to input the CSA in his worksheets, but it has caused much confusion for many folks who don't understand the basics of the various resonant devices used in speaker design. ==== >so, for any finished strait TL design, if you increase the cross sectional area it will improve the low end response?? Will that change the length of the line or the amount of stuffing? ==== Yes, though once the line's Vb exceeds ~10x Vas, any gains are tiny, just like when comparing a 10x Vas sealed cab to a true IB. ==== >The less you load the driver with it's own rear wave, the lower the resonant frequency of the driver and consequently the more output you will get at low frequencies for the correct line length. Once you unload the driver completely, it's resonant frequency becomes Fs and any gains from this point on will be minimal. ==== The driver's Fs doesn't change, only the amount the line damps its impedance peak changes. Once the line's Vb is large enough that no damping of its impedance peak occurs, then there will be no more gains. GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents. |
#12 |
Um, I hate to point this out, but for an open ended line, you are not loading the driver with a fixed volume of space, you are driving the rear wave through a wave guide so that it emerges in-phase with the front wave off the driver.
A transmission line is not a Helmholtz resonator. If you build a TL that behaves like one, you have failed miserably. Of course the line has a resonant behaviour, but the wave in the line is created at the fixed end, therefore for a standing wave to develop, it would have to be the front wave of the driver entering the open end of the line and combining with the rear wave. Compliance is the mechanical restorative force as generated by the suspension, which can also be expressed as a volume. It has units of N/m. In a sealed box system, compressing Vb by Vd (where Vd is Sd times the displacement of the cone in metres) produces a change in pressure between the inside and the outside of the box, which in turn exerts a restorative force on the driver, which is a function of the pressure multiplied by the cone area, (where the pressure is a function of the displacement), so cancelling out common terms you derive an enclosure compliance. Enclosure compliance is how we adjust Qts to get Qtc. Since there is no theoretical difference between compressing a finite volume of air, and trying to force too much air into a narrow pipe, a transmission line speaker behaves in much the same was a sealed box loudspeaker, except that at the resonant frequency of the line the front and rear waves constructively interfere to produce much greater output. This is why TLs have the slowest roll off of all and the driver doesn't suddenly unload and bottom out at high SPL when it hits the resonant frequency of the line. The only reasons that a driver mounted in a line of CSA = Sd would not behave as if in free space are if the end of the line is loaded against a wall or the walls of the line are not perfectly smooth. Since both conditions are ever present, it is necessary to approximate their effects, especially in the case of a stuffed TL, where the resistande of the damping material to airflow must be considered when trying to determine what the Qtc is and what the target line length should be.
Mark The king of all that is evil has left the building |
#13 |
==== Ah, but that's exactly what a closed pipe (plane wave tube) does in effect. It's a standing wave generator of 'x' Vb that drives a very thin acoustic 'membrane' (for lack of a better description) at its terminus where its length plus an end correction defines its resonant characteristics and its cross sectional area its displacement amplitude (gain). ==== >A transmission line is not a Helmholtz resonator. If you build a TL that behaves like one, you have failed miserably. ==== A ML-TL (TL with a vent) can be a 'beautiful thing' sonically if properly designed/implemented, so I definitely disagree with you, and judging by how popular they have become recently thanks to MJK's worksheet, so do many others. ==== >Of course the line has a resonant behaviour, but the wave in the line is created at the fixed end, therefore for a standing wave to develop, it would have to be the front wave of the driver entering the open end of the line and combining with the rear wave. ==== Nope, doesn't work this way. If it did, a sealed back driven PWT or horn wouldn't work. ==== >Since there is no theoretical difference between compressing a finite volume of air, and trying to force too much air into a narrow pipe, a transmission line speaker behaves in much the same was a sealed box loudspeaker, except that at the resonant frequency of the line the front and rear waves constructively interfere to produce much greater output. ==== Sorry, but comparing a sealed system to a resonant one is an apples n' oranges one. ==== >This is why TLs have the slowest roll off of all and the driver doesn't suddenly unload and bottom out at high SPL when it hits the resonant frequency of the line. ==== Well, they can if their Vb is quite small and are heavily stuffed, but F3 shifts up so high that I can't imagine anyone actually having a need for it in a HIFI app.. Indeed, unstuffed their roll off slope can be > a BR's/ML-TL's 24dB/octave if it has a very large Vb. Stuffed, it will ~match its IB equivalent, so for HIFI apps I have to disagree with your assertion. ==== >The only reasons that a driver mounted in a line of CSA = Sd would not behave as if in free space are if the end of the line is loaded against a wall or the walls of the line are not perfectly smooth. ==== Sorry, but this is just plain ridiculous. It's obvious we're poles apart, so I see no point in spending any more time on audio TL design theory until you have a better understanding of resonant air columns and how they mesh with T/S theory. GM
#14 | |
Now, I can see a few different physical models for the operation of the line. One, the terminus of the line is the acoustic centre of the driver and the open end is just that, the open end. Now if the line is one contiguous unit, then system would behave as if there were two wave sources at either end of the line and when they constructively interferred, that would be the resonance of the system. Two, the terminus of the line is fixed, and the driver is mounted somewhere in the middle. The driver creates two waves, with opposing vectors of propagation. When the wave that propagates towards the terminus encounters the terminus, it is reflected and inverted. When this wave constructively interferes with the other wave, that would be a resonance of the system. Three, as in the first model, except that there is a choke point somewhere in the line. When the backwave from the driver encounters the choke point, it is reflected. When the reflections destructively interfere with the backwave, the driver unloads, and this is a resonance of the system. I'm all too aware of the theory of a Helmholtz resonator, and thereby well aware of the problems such things cause, when accurate reproduction of recorded sound is the goal. If you honestly wish to listen to the reproduction of musical instruments through a device which behaves in much the same way, then that is your sacred right and I would not deny you that right. My goal is a critically damped bass system that does not exhibit the unnatural resonances, phase errors and group delay of traditional vented systems. I've not done a proper calculation of the Helmoltzian behaviour of such a system, but a quick look over the sizes of the quantities involved leads me to believe that the resonant frequency of it's behaviour as a Helmoltz resonator is very low, below the useful bandwidth of the system in fact.
| RT-2 Horn sub, the result | Elbert | Subwoofers | 126 | 2nd February 2009 09:51 PM |
| Nice Result | BAM | Subwoofers | 6 | 27th December 2001 03:56 AM |
| Page generated in 0.13269 seconds (81.37% PHP - 18.63% MySQL) with 10 queries |
