How important is a flat impedence measurment?
Could a speaker system be designed purposely with a bad, ie: not flat impedence curve and still sound good? If the amp drives the speaker just fine is it even an issue? Thanks!
My "cult-like" following is accepting applications. |
#2 |
Impedance doesn't matter unless the impedance is too low for your amp or you have a load sensitive amplifier, like many tube amps.
Our species needs, and deserves, a citizenry with minds wide awake and a basic understanding of how the world works. --Carl Sagan Science is a way of thinking much more than it is a body of knowledge. --Carl Sagan |
| Passive radiator specification measurment | gfiandy | Multi-Way | 0 | 15th December 2007 04:01 PM |
| CT impedence mismatch? | lpd | Tubes / Valves | 2 | 28th December 2004 01:34 AM |
| Impedence problems | wigginjs | Multi-Way | 7 | 29th January 2004 03:21 AM |
| Sd measurment of Dayton 6.5" woofer #295-306 | purplepeople | Multi-Way | 4 | 18th July 2003 10:04 PM |
| Page generated in 0.05687 seconds (67.75% PHP - 32.25% MySQL) with 10 queries |
