New CBT Woofers - diyAudio
Old 20th March 2017, 05:49 PM   #1
Patrick Bateman's Avatar
Default New CBT Woofers
When I heard the new CBTs at CES, I'd assumed that they were using the Dayton ND65 woofers. But they said they weren't, and that it used a new driver with improvements requested by Don Keele.
I believe the original CBTs did something similar; the Dayton ND91 has more BL and a shorting ring iirc. (It's based on the Dayton ND90.)
So...
Let's see what's going on with the new Dayton ND64, versus the old Dayton ND65.
From a quick look at the spec sheet, it looks like:
1) the new ND64 is cheaper
2) the new ND64 has half the xmax
I'd speculate that what they were trying to do is lower the moving mass. The MMS of the ND64 is 16% less than the ND65. This may contribute to it's high frequency extension.
It's a bit odd that Dayton overlooked a couple of other drivers in their stable. For instance, the Tectonic Elements TEBM35 has lower mms, flatter response, and lower cost than both the ND64 and the ND65.
(http://medleysmusings.com/tectonic-e...re-bmr-driver/)
Old 20th March 2017, 08:10 PM   #2
Patrick - Dayton doesn't make or own Tectonic Elements does it?
Old 20th March 2017, 08:18 PM   #3
I can't make heads or tails of the situation with Parts Express, Dayton Audio, and Aura Sound.
I bought some "Aura Sound" drivers last year, and their performance was quite a bit different than the published specs.
And AuraSound drivers were unavailable for about six years or so, from 2006-2012.
And Dayton ND90s look virtually identical to AuraSound NS3s.
Putting all of that together, I wouldn't be surprised if some factory in China simply started stamping out replicas of the old AuraSound drivers. Or perhaps they even bought the tooling?
Tang Band speaker was founded twenty years ago, but all of those old AuraSound spec sheets are signed by "Ben Tang." Coincidence?
Old 20th March 2017, 08:47 PM   #4
jrh0516 is offline jrh0516  United States
jrh0516's Avatar
The baskets on the NS3s and ND90s are were different on my 2015 models
I assume you saw this thread Nice, ND64's for us! - Techtalk Speaker Building, Audio, Video Discussion Forum
John H
Old 23rd March 2017, 12:32 AM   #5
So...
Don's partner was involved in the driver design so that's why the Tectonic drivers weren't used. The goal was to have a driver with a rising response to counter the CBT's downward sloping transfer function.
Old 23rd March 2017, 07:21 AM   #6
Omholt is offline Omholt  Norway
Omholt's Avatar
For a passive CBT you have to use a driver with a rising response like Craig says. So that limits the options.
Besides, Dayton is PartsExpress own brand, and obviously they would prefer using their own.
Bjorn
www.lydogakustikk.no
Old 23rd March 2017, 05:02 PM   #7
Why not use a standard tone control, possibly supported by a tailored passive shelving filter with a few dB lo-frequency attentuation? 3 dB per octave as in CBTs is a common recording margin anyway, some recordings are brighter, some duller, some nuttier, some french-beddier.
Uli
Old 23rd March 2017, 06:28 PM   #8
Omholt's Avatar
Uli
That's possible. From a commercial standpoint though and when offering a passive speaker, it may not be the best move.
Bjorn
Old Yesterday, 12:18 AM   #9
I mixed up octave and decade: A driver model with flat response causes a CBT made of such drivers to fall by 3 dB per octave, but recording margins are usually within 3 dB per decade. If Don had used a flat-response driver model for his new home CBT, the treble control would have to be turned up all the way.
Old Yesterday, 02:15 AM   #10
jrh0516's Avatar
The CBT demo'ed at MWAF in 2016 used a DSP. It would be interesting to know if there are any passive components in the CBT 24 as it's preassembled.
John H
Alpair 7 used for Keele CBT Array HiroPro Full Range 9 11th March 2016 11:25 AM
(2) ScanSpeak 25W/8565 woofers, (4) HiVi D6.8 woofers, (2) Eton 7-373 Hex B woofers Jimmy154 Swap Meet 14 11th July 2015 09:11 PM
Floor-to-ceiling array vs CBT jeno Multi-Way 196 23rd September 2014 02:54 AM
Building some CBT clones ... rhubarb9999 Multi-Way 26 11th September 2013 03:30 AM
Copyright 1999-2017 diyAudio
