Hi all,
I'm just drawing up some plans on a new loudspeaker I'm going to be making shortly. Its a sort of no holds barred experiment and I want a very competent HF unit. I've been looking at the Raven R-1, Seas-Excel 'Millenium' as well as the ScanSpeak 9900 Revelator. Any suggestion as to which of the above (if any) has the ability to transform recording into reality? |
#2 |
Account Disabled
No holds barred? Here you go:
http://www.plasmatweeter.de/acapella.htm These $2500 plasma tweeters are used in speakers such as the $120000 Acapella Spharon: http://www.acapella.de/german/spharon.htm Hey, you siad no holds barred
#3 |
I currently use the seas Millennium in my last speaker, 3 way dipole with electronic crossover dedicated with equalizer + alignment of the acoustic centers for every driver.
Attention to the sound of the Millennium, is very detailed to the middle and the middle high frequency but it is a little airy to the high frequency, compared with tw type ribbon it has a very closed timbre, the impression is that to listen aloft to an answer in limited frequency, an answer with a precocious roll-off. The general quality is tall but the dark timbre is particular, can reveal disappointing as unfortunately in my speaker. I don't succeed in accepting this type of sound, I believe that I will change the tw with model to ribbon. Valter |
#4 |
If the rest is going high enough this one might be for you:
http://www.pioneerelectronics.com/pn...etailComponent It is used in this monitor: http://www.strauss-elektroakustik.co...s/1_ttmf_2.jpg Comment about that monitor: http://www.swissaes.org/nl/aes_newsletter_80.pdf Regards Charles |
#5 |
Accuton has a diamond coned tweeter for $2800 each. Yes, a diamond cone.
If it sounds good... it is good! |
#6 | |
Regards Charles |
#7 | |
#8 | |
Regards Charles |
#9 |
Cheers for all the suggestions, though I doubt that I will ever consider spending $1000+ on single drive unit.
So maybe I should rephrase the 'no-holds barred' bit Let's say recommendations for HF under $250 each. I'm thinking that ribbon is the way to go and specifically the Raven 1 but I'm still of course undecided. More suggestions needed. |
#10 |
The Raven is defenitly a much better tweeter than the Seas or the Scanspeak but is also the most difficult one of the three to combine with a good mid-range driver. You will have to look for a driver that is fast enough, dynamic enough and smooth enough to come up with the Raven, else the coherence between the drivers would be dissapointing in the end, so using the Ravens will not automatically lead to an overall better sound.
What mid-range did you have in mind ? |
| help treble | tadiam | Chip Amps | 4 | 26th August 2007 10:44 PM |
| Page generated in 0.11282 seconds (77.31% PHP - 22.69% MySQL) with 11 queries |
