Will this design work? (Drawings) - diyAudio
Old 18th March 2017, 12:05 PM   #1
Default Will this design work? (Drawings)
I'm planning to make two floor standing speakers. Will this 45 degree effect sound negative? I just want to look this way but i'm not sure about audio effect. Main driver is 4" 25w cheap chinese driver. angle is 45 degree and top part is also 45 degree to body. 90 degree to driver. I will build with 18mm bamboo plywood. Please let me know about your thouths and suggestions.
Old 18th March 2017, 12:36 PM   #2
fluid is offline fluid  Australia
If that is a tweeter in the front face and a woofer angled in the top then I think you will get a pretty weird response.
The tweeter is likely to be a good way out of time alignment with the woofer and will have a lot more direct sound being on axis, the woofer will mainly be heard off axis or from the reflector panel, I would think you would get a lot of diffraction from the edges of both the cabinet and the reflector.
Old 18th March 2017, 12:52 PM   #3
jrh0516 is offline jrh0516  United States
jrh0516's Avatar
I'd say It would be worth measuring. I kind of prefer the fixed reflector vs. relying on the room.
A bit wider baffle and deflector would push down the baffle deflector diffraction
John H
Old 18th March 2017, 01:03 PM   #4
Thanks for answer. As you see I don't have any knowledge or experience about audio. But I like designing. Yes there's a tweeter in the front. So what can you recommend? I'm not looking for "audiophile" sound. Even with best design, my electronic will not sound best. But at least I want some decent results. I can change design if you (or anyone) have suggestions.
Thanks again!
Old 18th March 2017, 01:06 PM   #5
scottjoplin's Avatar
Usually speakers are mounted horizontally to aid dispersion, this seems half and half but then the reflector negates that anyway. Is this purely for aesthetics? Where did you get the idea?
What came first, the music or the misery? Nick Hornby https://www.youtube.com/watch?v=nSlleE9s9gI
Old 18th March 2017, 01:08 PM   #6
Sonce is offline Sonce  Macedonia
Remove the top reflector - it is totally unnecessary. Woofer at 45 degrees will diffuse the sound, something like a Bose speaker - love or hate case.
Old 18th March 2017, 01:14 PM   #7
Thanks all for answers,
I designed this on sketchup. I dont really have any idea about sound dispersion or other technical things about audio but want to learn and design/built more. Is there any way to keep design but change angles or positions of drivers? I want to keep main design but for sure if it will give me horrible sound i can change the shape.
Old 18th March 2017, 01:15 PM   #8
It's there as a part of design. Totally visual. if it wont effect negatively i would like to keep it this way.
Old 18th March 2017, 04:38 PM   #9
If you want to keep the reflector then I would suggest you place the tweeter as close as possible to the woofer, at least it would then be serving a useful purpose.
Old 18th March 2017, 05:16 PM   #10
What about placing tweeter to reflector? Facing to woofer at 45 degrees. Please be nice I'm totally newbie ��
Will my design work? vaustin89 Solid State 11 19th April 2012 10:36 AM
Need some design help...will this work? boogs Multi-Way 0 10th October 2006 01:45 AM
HELP--What sub design would work best for this? jjkozlow Subwoofers 13 17th June 2005 09:59 PM
Dipole design -will this work? Ian J Multi-Way 15 3rd August 2003 01:06 AM
Copyright 1999-2017 diyAudio
