Will this design work? (Drawings) - Page 2 - diyAudio
Old 18th March 2017, 05:44 PM   #11
scottjoplin's Avatar
Can you do a sketch, show what you mean?
What came first, the music or the misery? Nick Hornby https://www.youtube.com/watch?v=nSlleE9s9gI
Old 18th March 2017, 06:07 PM   #12
Oh it's 2am here. But tomorrow morning I will share. Just put the tweeter underneath that reflector. Facing downwards to woofer. Two drivers (woofer and tweeter) will face each other at 45 degree.
Old 18th March 2017, 06:11 PM   #13
No, I meant mounted next to the woofer pointing in the same direction. What you suggest is definitely not a good idea. . Good night
Old 18th March 2017, 06:36 PM   #14
Lojzek is offline Lojzek  Croatia
Lojzek's Avatar
Originally Posted by AquaDesignHK View Post
Please let me know about your thouths and suggestions.
Aesthetically it's not a good design as if you wanted to create an anubis like looking object. Beauty is in the right kind of curves and if you'd like to do something with sharper edges then look for the Dynaudio Facette speakers which is a very good looking product, imo.
Being good or bad is just a matter of practicing habits, good or bad. Once you get used to it, it's easy.
Old 18th March 2017, 06:58 PM   #15
DonVK is offline DonVK  Canada
DonVK's Avatar
Default Experiment result - rectangular reflector
This got me interested, and enough votes are in, so let's see what the experiment says. This is using my Omni cabinet, 21cm woofer, LR4@1.8Khz. There can be other issues with a tall cabinet behind a woofer but lets see what a rectangular reflector does.
The FR graphs are nearfield (20cm@30deg from woofer center). Things get worse as the rectangular reflector approaches the woofer. Its from destructive interference as sound reflects off the panel.
I should also add, you can get this effect if you place your speaker close (against) the wall.
Old 19th March 2017, 02:17 AM   #16
fluid is online now fluid  Australia
Don's measurements show why short distance reflective surfaces create dips in the frequency response based on their dimensions relative to wavelength.
Have a look at Linkwitz's LX Minis and Pluto projects. Lots of information there and reading through that will probably help you to understand more of the mechanics involved.
That being said using no name chinese drivers, limited knowledge and no experience with crossover design coupled with an unusual cabinet design means you are certainly choosing to do it the hard way!
Old 19th March 2017, 02:39 AM   #17
Thanks for shearing your thoughts. I checked Dynaudio Facette, personally i didnt like it. I mean beautiful but not for me. I know that beauty is subjective value, its good to hear another voice. Thanks again. I will re-design and share the sketches. please do comment again.
Old 19th March 2017, 02:46 AM   #18
I really appreciate your work. Thanks a lot. Although i didnt understand anything about graphs (well I think 20-75 hz is not good) i understand that reflector will not a good idea. actually it wasnt thought as reflector in the designing but became one so i will add some new drawings. Hope you will write something again.
Old 19th March 2017, 02:49 AM   #19
Actually i saw that pipe(ish) designs. So their tweeter facing front but woofer facing upward. Let me make another sketches. Thanks again I appreciate all comments.
Old 19th March 2017, 02:55 AM   #20
DonVK's Avatar
The graphs show the performance of the woofer, for various angles of your reflector [ no reflector, 90deg, 60deg, 45deg ]. Ignore the graph response for <75Hz it does not matter for small woofers. Its the upper frequencies >800Hz are experiencing destructive interference (large dips). In a 2 driver system, your woofer will need to operate up to 2->3Khz at least, and this system is having problems at 0.8KHz.
Will my design work? vaustin89 Solid State 11 19th April 2012 10:36 AM
Need some design help...will this work? boogs Multi-Way 0 10th October 2006 01:45 AM
HELP--What sub design would work best for this? jjkozlow Subwoofers 13 17th June 2005 09:59 PM
Dipole design -will this work? Ian J Multi-Way 15 3rd August 2003 01:06 AM
Copyright 1999-2017 diyAudio
