Will this design work? (Drawings)
Old 20th March 2017, 12:19 PM   #31
DonVK is offline DonVK  Canada
DonVK's Avatar
Originally Posted by AquaDesignHK View Post
Do you mean like this? I will need larger space for this am i right? I mean i calculate the chamber that speaker stay is about 5,6 litre exactly what manufacturer recommend. If I add one more speaker do I need double space?
I agree with Scott, the tweeter needs to be roughly at ear listening level.
Yes, 2x drivers means 2x volume but you'll also get much better bass from small speakers.
I can't tell how high the cabinet is. One drawing has a vertical tab at the back (oblique to top woofer) of the cabinet for a tweeter. That would be one location because it would be parallel to the wall and raised to ear listening level. However it does cause a phase shift problem from the woofer. Another solution is to put the tweeter as high up on the front surface so its aligned to the front woofer.
Are you sure you don't want to use 2 full range speakers for this, and avoid the other issues?
Old 20th March 2017, 01:12 PM   #32
AquaDesignHK is offline AquaDesignHK  Hong Kong
I really appreciate guys, you already taught me a lot. So, what about this drawing?
And I want to ask should I double the cabinet volume due to 2 speakers?
Speaker itself about 60cm without that tweeter board. I thought it can be even place on the TV stand. The guy in the drawings is about 180cm tall. He can give some idea about scale.
Old 20th March 2017, 01:22 PM   #33
fluid is online now fluid  Australia
If you bring your tweeter plate down to where the bottom of the angled woofer is and put the other woofer underneath the one on the base you would have a TMM style with the tweeter being reasonably time aligned. Much more conventional but likely to be more successful.
By combining radiation in different directions from the same type of drivers will create interference patterns. This can be helpful if you know what you are doing and can control the relative levels or EQ of the drivers like the Beolab does.
In your picture it is more likely to create destructive interference and peaks and dips in the response.
Cabinet volume is dependant on the parameters of your drivers, do you have any Thiele Small parameters for them. Also whether it will be sealed or vented.
Old 20th March 2017, 01:30 PM   #34
DonVK's Avatar
I agree.
Old 20th March 2017, 01:47 PM   #35
Oh I dont really understand the placement. (My bad English)
I attached the graphs that manufacturer provided. and the other informations are like this;
Rated power: 35W
Maximum power: 50W
Peak power: 100W
Effective frequency: 75Hz-5500Hz
Sensitivity: 86dB
Qts: 0.56
Cabinet volume: 5.6L
I designed as sealed. No any reason just easier. I think vent hole and insert pipe also need some calculation. I feel very down now. I think it will ended up ordinary book shelf speakers; woofer and tweeter in the front. But I want to make something visually different and pleasing.
Old 20th March 2017, 01:55 PM   #36
scottjoplin is offline scottjoplin  Wales
scottjoplin's Avatar
In my mind I saw it as a floor stander. Obviously that's not the case, so, from an aesthetic point of view you could place the tweeter wherever you want and adjust height with the stand. I still recommend though that you place it as close as possible to the woofer. Also you mentioned a 2.1 amp, are you planning to use a subwoofer?
Subwoofer Assisted Wideband is the New Testament renounce the anachronistic acronym FAST
Old 20th March 2017, 03:03 PM   #37
I have a TEAC subwoofer leftover. I will use it for now and make a simple cube subwoofer box later. So... Since everything is very cheap, I'll take this as experimental design.
Old 20th March 2017, 11:42 PM   #38
Like this, I chopped your picture up a bit but hopefully you get the idea.
Will this design work? (Drawings)-png
Rated power: 35W
Maximum power: 50W
Peak power: 100W
Sensitivity: 86dB
Qts: 0.56
The last page is the most useful as it lists the T/S parameters put these into a box program and it will tell you the optimum cabinet volume.
There are some strange things in that Qts is shown in the image as 0.52 and not 0.56, but Vas at 5.6L is the same as the cabinet volume they have listed.
Making the cabinet the same size as Vas will work but it may not be optimal.
Sealed is fine but those woofers won't go very low in a sealed cabinet.
Make it however you want it to look, but the image I just posted will work a lot better as a speaker!
Old 21st March 2017, 02:17 AM   #39
zman01 is offline zman01  Bangladesh
I just want to make decent speakers for listening music with some nice looking handmade touch. Maybe I can give it to someone as gift. I thought it would be nice next to TV for using with TV and music player.
Is it really dramatically effect that distance to wall or shape of the room? Houses are so small in Hong Kong. I mean will it be disturb any ordinary person that not especially looking for HIFI sound?
AquaDesignHK,
For your goals, you might want to check out wide-band (aka full-range) drivers. I know this is the multi-way forum, but given the design brief, I thought I'd suggest.
Mark Audio, one of the popular wide-band brands among diyA folk, are based in Hong Kong, so should be easy for you to check out.
An "up-firing" design that might interest you:
microTower bipolar ML-TL for CHR-70 or EL70
Old 21st March 2017, 05:07 AM   #40
fluid, Thanks mate, I got it now. Probably I will go for single woofer + tweeter. Maybe just ordinary tower speaker. I will try something different maybe next time.
zman01 Thanks for the link. I heard about his speakers, seems very good quality. I don't know the price range but must be way way over this projects budget. Definately i will go for full range drivers next time.
Will this design work? (Drawings)Hide this!Advertise here!
Will my design work? vaustin89 Solid State 11 19th April 2012 10:36 AM
Need some design help...will this work? boogs Multi-Way 0 10th October 2006 01:45 AM
HELP--What sub design would work best for this? jjkozlow Subwoofers 13 17th June 2005 09:59 PM
Dipole design -will this work? Ian J Multi-Way 15 3rd August 2003 01:06 AM
Copyright ©1999-2017 diyAudio
