Visaton 2 way tower or Monitor Audio Bronze 5 - Page 2 - diyAudio
Old 15th March 2017, 02:13 PM   #11
Mrcloc is online now Mrcloc  South Africa
Thanks. I've started to play around in boxsim. I'm just no good with crossovers. I think I get the basic idea, and I'll see what I can do.
Old 15th March 2017, 02:52 PM   #12
A little tweaking here and there, and I get this. Any comments? How accurate is boxsim? This is with a CP13 tweeter.
Old 15th March 2017, 02:55 PM   #13
This is the crossover.
Old 15th March 2017, 03:36 PM   #14
system7 is offline system7  United Kingdom
system7's Avatar
That won't work at all. Puny tweeter just not up to it.
https://boxsim-db.de/kategorie/systeme/drei-wege/
These designs can be imported straight into the projekte folder and adjusted.
Most of them aren't actually that impressive, but a good start.
There's no replacement for displacement with bass. But the SEAS Bragi MTM is a good one for an authoritative sound. And series wiring two 4 ohm basses is also a good one. Or you can add a sideways firing bass or two as in the Devore Fidelity Gibbon X.
Your impedance correction can't be right for two series wired W130S-4 basses. You need to check that. I get 8.75R/15uF.
mh-audio.nl - Home
W 130 S - 4 Ohm
You have to double the DC Resistance (3.5R) and Inductance (0.6mH) with two in series. Bafflestep is a moveable feast. 4dB is usually about right. But if you want more bass, you definitely need bigger drivers.
Best Regards from Steve in Portsmouth, UK.
Old 15th March 2017, 03:45 PM   #15
Ok, thanks. I got those values too, but I didn't know how to smooth the curve.... I'll look further into this. I unfortunately don't have access to anything, except Visaton, and then no name stuff. PA speakers are readily available, but those won't cut it.
Old 15th March 2017, 04:10 PM   #16
system7's Avatar
I wasn't suggesting SEAS drivers at all. But any project should be based on a good idea that works. And MTM is a good idea.
The W130S is quite a difficult driver, IMO. You'll probably find the W170S-4 easier.
These tweeters are worth looking at:
G 20 SC - 8 Ohm
SC 10 N - 8 Ohm
DT 94
TBH, tweeters are fairly interchangeable. The SC10N and DT 94 (which I have used) are louder 91dB types, the G20SC is a 88dB type which Lojzek has said nice things about.
Old 15th March 2017, 04:26 PM   #17
Legendary advice, which I very much appreciate!
Old 15th March 2017, 04:31 PM   #18
system7's Avatar
Lojzek's splendid dumpster diving seems to have rustled up a fun tweeter there:
Here's some Visaton experiments I did a while back. Both pretty good.
8" W200S-8, DT 94 and TW 70 cone tweeter. Actually the port was a bit small, so I fitted an old Sony 8" bass I had lying about.
Old 15th March 2017, 04:51 PM   #19
So what so you think would be better, 2xW170S, or 1xW200S? And 2xW200S? Will that do well? Perhaps 1xW200S and 1xW170S, or even a W100S? I'm going to play around with these in boxsim tonight, but I have absolutely no experience with these drivers, or really with high-end multi-way speakers. I'm trying to get something that will blow my Celestions away, and they're pretty good.
Old 15th March 2017, 05:44 PM   #20
I think the main thing with the Celestions is that they lack a little definition in the midrange, and they're not balanced at low levels.
Kef vs Monitor Audio Alan0354 Multi-Way 15 27th March 2015 09:35 AM
Wanted: Monitor Audio Monitor 7 tweeters hatrack71 Swap Meet 0 23rd November 2014 10:01 AM
wilmslow audio monitor jbj1 Multi-Way 24 23rd October 2014 02:36 PM
O-scope to monitor audio genel Equipment & Tools 2 11th September 2009 10:59 PM
Klipsch vs Monitor Audio asynchrono Multi-Way 1 13th May 2007 12:25 PM
Copyright 1999-2017 diyAudio
