Old 17th March 2004, 06:05 PM   #1
Default Need High Spl Box
OKAY I NEED HELP,BUILT 15" SCOOP CABS OUT OF FANE BOOK.DROPPED IN SOME EMINANCE SPEAKERS SOUND ALRIGHT,PUT IN SOME PEAVEY 15" SOUND BETTER . I DJ ON THE SIDE ,WOULD LIKE TO BUILD SOME CABS WITH HIGH SPL SIZE DOES NOT MATTER"AS LONG AS IT IS NOT MADE BY MAYTAG(ICE BOX SIZE)"DOES ANYONE HAVE DESIGN FOR 12s OR 15s WITH HIGH SPL.FOUND BOX CALLED LAB 12 ON NET THIS THING HAS SAME BASS AS 6 18's .WOW!!!! ANYONE TRIED THIS DESIGN?
Old 17th March 2004, 09:04 PM   #2
mikee12345's Avatar
yes its true
many people use it
135db continous etc. down to 30hz
http://campuisen.com
http://www.hometheaterforum.com/htfo...threadid=70277
http://www.geocities.com/sc00byd0159/td.txt
Cheers
Old 17th March 2004, 10:06 PM   #3
REDSKIN is offline REDSKIN  England
Default hi spl box
Picked this link up from another thread on this forum thought it might help. There's about a zillion designs to chose from so one must work!
http://www.paforum.de/paforum/viewto...=183890#183890
Hope it helps.
He shoots. He scores!
Old 18th March 2004, 12:50 AM   #4
mikee12345's Avatar
the labhorn IS the best!
Computer optimised driver specs!
the measurements prove it also.
tom danley on the labhorn.
http://www.f16.parsimony.net/forum27...sages/3122.htm
shoout out site.
http://www.tandartsgroep.be/shootout/
Old 18th March 2004, 06:16 AM   #5
Default LAB 12
Eugene
I have friends who have built the LAB 12, and while a little more complicated than just a scoop (it is a bass horn with driver covers), I think you have to go into much more exotic boxes to meet or exceed the output.
The LAB 12 was designed for pro sound use(named after and a project for the "Live Audio Board"), preferably in multiples or stacks to couple the outputs. But, I have heard these several times in different settings, and with just one unit corner loaded the building couldn't handle the output without everything in it dancing. Massive bass. What a blast!
Takes two drivers, though, per horn. The box is large.
I liked it so well that I built a bass horn too, and although I didn't use the LAB 12 woofers, I wished I had. Lower distortion, bullet proof construction. Just home audio - really overkill - but excess is good now and then.
Tim Moorman
Power supply:Universal AC input/ Full range,High Efficiency, and High reliability hang Vendor's Bazaar 12 24th July 2009 03:46 AM
Wanted - High Power, High Voltage, Audio Frequency Transformer Manual. kimbal Tubes / Valves 4 11th May 2009 08:05 PM
I coined the phrase HIGH VIVIDITY, to differentiate our amps from High Fidelity ones vax9000 Tubes / Valves 8 31st October 2006 01:10 AM
6BY5 High Voltage & High Current Choke Input Design P.S. snoopyma Tubes / Valves 7 28th June 2006 01:32 PM
high gain 2nd order high pass active filter topology sreten Solid State 21 23rd March 2006 01:26 AM
Page generated in 0.08790 seconds (71.74% PHP - 28.26% MySQL) with 11 queries
