Help inductor.  Parallel windings of thin wire to make one?
Old 20th March 2017, 12:10 PM   #81
Butcher is offline Butcher  New Zealand
Butcher's Avatar
"Using my old rule of 1:1:4 (which may not be best)"
We will see. I like my own rules... Probably crash and burn, but learn something along the way!, possibly ???
"I wrap thick cotton/nylon thread in blanket stitch to help hold the turns together."
Andrew, must sound good then.
thanks for sharing directions instructions for home brew, self wound. I was feeling alone! Build your own equipment folks and be prepared to learn from mistakes....... Fun.
Old 20th March 2017, 12:14 PM   #82
Butcher's Avatar
I nursing windings. Those little puppies can be rubbed against bricks. Sharp obstacles for us sensibles.. Producing inductors is fun. Should be undertaken and understood. Make one, stuff that up and learn but think about previous goal and move on...
Old 21st March 2017, 06:29 AM   #83
Butcher's Avatar
I measured 2.48mH. I require 2.54mH, so not bad! I need to wind on some more windings.
I had a bad thought that paralleling two inductors in parallel would half the inductance. My theory was luckily incorrect!
Also, DCR is 2Ω per winding. Paralleled up equals 1Ω (measured). This is a tad high. But acceptable as 60L cabinets with 12" drivers is not so good living with neighbors close by... So Z = 8Ω + 1Ω DCR in series. I might have to attenuate mids and tweeter somewhat. As I run .FLACs from my PC, I can use digital eq.
Total weight is just under 300g.
With our 12dB / octave designs, I may have to use thicker wire. I will provide photo of my mates 6 foot high home-wound NZ hardwood speakers and also mine (old Philips ones) at later date.
Thanks.
Old 22nd March 2017, 04:15 AM   #84
Butcher's Avatar
Completed inductors. They are both 2.54mH and WELL within 1%.
Old 22nd March 2017, 04:20 AM   #85
DonVK is offline DonVK  Canada
DonVK's Avatar
Congrats, they look good. Truly DIY.
Must be nice to know you can change them at will, without a 1 wk delay and shipping charges.
Old 22nd March 2017, 04:39 AM   #86
Butcher's Avatar
Hey DonVK! Thanks. Yes, shipping charges, GST (tax), not made in China (as opposed to NZ!), and My coils are spot on in inductance.
I may have to wind with thicker copper though.
Final dimensions are 27mm former, 35mm wide and 0.8mm copper windings (x 2 to make 1.6mm dia.) are about 14mm deep.
I might mount the board and inductor to a sheet of ply and screw it to inside of cabinet. Finally I am going to line all inside panels with stuffing from an old duvet and use some yellow glass fiber insulation that was installed previously. When I stick my head into the 60L cabinets and yell, there is a $hit load of echo. Hopefully they will sounds good!
Old 22nd March 2017, 05:29 AM   #87
DonVK's Avatar
I buy sheets of this stuff for proto PCB work. You can cut it to shape, solder to one side and drill it easily for mounted components. The only place I can find large sheets is HK.
This is one sheet cut in half http://www.diyaudio.com/forums/multi...ml#post4992538
https://www.amazon.ca/gp/product/B00...?ie=UTF8&psc=1
Old 22nd March 2017, 05:39 AM   #88
Butcher's Avatar
Thanks DonVK, yes Yuor prototype boards are looking good! Loop the legs of heavy components thru the board for extra support... I intend on getting my act together and make circuit boards. I have all them chemicals for photo etching. I just need to buy some lamps and mount inside an old flatbed scanner!
I like the sound of my 6dB board so far. I will build some 12dB ones for myself after completing my mates speakers...
Here is my setup being tested (sort of). Still some work to do. Boy it sounds much better! I want to crank it...
Old 22nd March 2017, 06:52 AM   #89
Butcher's Avatar
Listening to some good music and allowing ears to adjust. Close eyes and focus into different instruments. Sounding real good... (Not quiet finished yet).
Old 22nd March 2017, 10:24 PM   #90
DonVK's Avatar
Looks like you have some vintage gear. Do you collect? or resourceful
Help inductor.  Parallel windings of thin wire to make one?Hide this!Advertise here!
how to make a 2.0 mH inductor with 15 awg wire srinath Parts 32 3rd April 2015 12:29 PM
Output Transformer Windings in parallel apnneto Tubes / Valves 15 3rd February 2015 02:56 PM
In need really thin aluminium magnet wire!!! WrineX Planars & Exotics 20 2nd April 2009 07:00 PM
Parallel secondary windings jlm Pass Labs 6 27th March 2004 11:39 AM
Using thin wire between driver pcb and mosfets Lucas_G Pass Labs 4 15th August 2003 12:18 PM
