Help inductor.  Parallel windings of thin wire to make one?
Old 20th February 2017, 09:31 AM   #11
Tweet is offline Tweet  Australia
Hi Butcher, Here is an easier way of obtaining coils and whatever else you may need.
I hope this helps.
SpeakerBug
C.M
Old 20th February 2017, 09:46 AM   #12
Butcher is offline Butcher  New Zealand
Butcher's Avatar
So wire is hex in shape ? Hahaha
Old 20th February 2017, 09:55 AM   #13
Butcher's Avatar
Hi Tweet!
Yea I bought set of crossover boards from Jaycar about 8 years ago. Populated with PPE dielectric caps and wound half of the inductors.
I am also after advice in low inductance resistors. I have measured resistors of 2 ohms and discovered high inductance. I admit that most of this is caused by BS by not factorising R.
Here in NZ there is not much choice of 'splurging' into components.
Thanks Tweet! Nice to meet etc.
I can take photos of current (bad pun) setup. I appreciate all your help !
...gonna make high Z inductors, if it urgs (bad pun) me!
Size doesn't matter too much. Balance between size and insulation does.
Old 20th February 2017, 09:57 AM   #14
Butcher's Avatar
ps. power handling requirements = 100W RMS DIN or less, total... (50W p/channel)
Old 20th February 2017, 10:34 PM   #15
Ron E is offline Ron E  United States
Ron E's Avatar
Originally Posted by Butcher View Post
I guess making 4mH inductor would be about 10 times the size of a 0.4mH one? I understand it has to do with 'turns ratio'. I am guessing that DC resistance would be higher, due to 10 (?) times the number of turns.
Inductance varies as the number of turns squared, so it only takes twice as many turns to get 4x inductance.
If you are winding your own, you can use a railroad spike or 1008 (low carbon) steel bar stock (even bundled nails might work in a pinch) and get roughly 4x the inductance. I think iron core like to have fewer layers with more turns per layer.
I would use at least 3 strands of wire, as that is more space efficient than 2.
Our species needs, and deserves, a citizenry with minds wide awake and a basic understanding of how the world works. --Carl Sagan
Armaments, universal debt, and planned obsolescence--those are the three pillars of Western prosperity. Aldous Huxley
Old 20th February 2017, 11:27 PM   #16
Butcher's Avatar
Thanks Ron E.
I am not concerned about space or size of inductors. My personal speaker box is 60L. My friends ones are much larger volume than that. Inductors will be mounted securely.
Again, I am trying to avoid iron cores. I have lots of free 0.8mm diameter copper wire. I will look into winding may be three strands of 0.8mm in parallel. Thanks.
Few questions, how tightly should I wind the three strands?
Also, any ideas on material for bobbin? I am thinking PVC pipe with wooden disks for ends. The discs I can cut out using a wood hole cutter.
I will take some photos of progress so far.
By the way, I have chosen cutoff points as, 500Hz and 5KHz.
Old 20th February 2017, 11:47 PM   #17
JMFahey is offline JMFahey  Argentina
JMFahey's Avatar
Short answer and nor digressing like some of the contradicting advice above.
1) do not twist them, no need to and in fact it increases total resistance
2) all turns must have the exact same number of turns and be wound around same axis (which may be some kind of magnetic one or simply air/vacuum)
3) one way to guarantee that is to wind many strands at the same time.
No need for the pack to be roughly circular, it may naturally form a rough "ribbon" when held by your guiding hand, no big deal.
4) in that case, inductance will come mainly from amount of turns, and core diameter , while DC resistance will be directly proportional to wire length and inversely proportional to number of strands in parallel, which will dictate equivalent wire section.
Source: I commercially design , wind and sell Musical Instrument transformers, both Power and Output types, and often rely on multiple windings of easier to wind thinner wire, which are later put in parallel.
Design/make/service musical stuff in Buenos Aires, Argentina, since 1969.
Old 20th February 2017, 11:55 PM   #18
audiofan is offline audiofan  Canada
If you need to calculate inductors look for '' weeler formula'' & '' brooks coil ''.
But if you need to make stranded wire DO NOT US A DRILL it is not the way to go .
With a drill the wires will not only wrap aroud each other ... they will twist ... if you make a stranded wire with several small wires and twist them together with a drill and make 300 turns ... each wire will also have make 300 turns on themself ..and this will damage the wire .
Old 20th February 2017, 11:55 PM   #19
nigelwright7557 is offline nigelwright7557  United Kingdom
nigelwright7557's Avatar
I have seen multi strand windings in SMPS transformers.
PCBCAD51 pcb design software. 2018 version out now with lower prices >> http://www.murtonpikesystems.co.uk
Old 21st February 2017, 12:40 AM   #20
Hi Butcher, me again, I though you were in Australia, a mix up with the flags.
Heavens, they should just build a bridge between the two countries and be done with it.
In regard to non-inductive resistors you could use the nichrome wire in those old electric jug elements (the porcelain insulator type), just wind the wire in one direction then in the other with the proviso of insulating one layer from the other.
Actually, non-inductive resistors generally provide very little benefit in passive crossovers because the audio frequencies are too low, any inductive reactance of a normal wire wound resistor likewise is essentially trivial at audio frequencies so making your own is likely to have inaudible results.
If you were to make an iron cored inductor it is best not to use nails or ordinary iron parts as they tend to have high retentivity and poor permeability. Audio transformer cores are best suited for the purpose if you decide to make your own laminated iron core inductors. Just a few thoughts.
C.M
Help inductor.  Parallel windings of thin wire to make one?Hide this!Advertise here!
how to make a 2.0 mH inductor with 15 awg wire srinath Parts 32 3rd April 2015 11:29 AM
Output Transformer Windings in parallel apnneto Tubes / Valves 15 3rd February 2015 01:56 PM
In need really thin aluminium magnet wire!!! WrineX Planars & Exotics 20 2nd April 2009 06:00 PM
Parallel secondary windings jlm Pass Labs 6 27th March 2004 10:39 AM
Using thin wire between driver pcb and mosfets Lucas_G Pass Labs 4 15th August 2003 11:18 AM
