Why the tweeter needs its own full bandwidth amplifier - Page 3 - diyAudio
Old 14th February 2017, 05:32 AM   #21
There was also some research by John Meyer on those forces that are working against tweeter diaphragms. But that was for highpowered systems using HF horns. Horns make the situations worse.
There will be an effect for sure also in a home environment. But I don't know how severe it is. I will definitely continue using a cap in series of my tweeters in active speakers because burnt voice coils do definitely hae a detrimental effect on sound.
Charles
Old 14th February 2017, 09:01 AM   #22
So it does. lol
Old 14th February 2017, 09:55 AM   #23
john k...'s Avatar
The microphonics of a typical tweeter in a home system is insignificant. But if you are worried about it, remember, that the tweeters typically have fairly high mechanical damping, particularly if they have ferrofluid, and if you are concerned about the back emf, all that would be required is an amp with low output resistance across the audio band, regardless of its power bandwidth. And heaven forbid that you use a tube amp with high output Z.
John k.... Music and Design NaO dsp Dipole Loudspeakers.
Old 14th February 2017, 01:28 PM   #24
pkitt is offline pkitt  United States
Agree and very troll-like IMO.
Paul
Originally Posted by 1audiohack View Post
I don't think it was a question.
onaudio seems to pop up with something he thinks is factual, make the statement and disappear.
Whatever.
Barry.
Old 20th February 2017, 09:19 AM   #25
Dome it is
Originally Posted by Tromperie View Post
And? Is there any point to the OP? Who has a tweeter "cone" these days anyway?
Another for the list.
Old 10th March 2017, 12:39 AM   #26
At least it means I don't have to see another of his/her posts.
Old 11th March 2017, 05:27 PM   #27
Originally Posted by Nico Ras View Post
This is a rather interesting question from OnAudio.
It wasn't a question...
Old 11th March 2017, 09:32 PM   #28
john k...'s Avatar
Just another point to make here. An amplifier will have little or no effect on damping the movement of a tweeter at low frequency, or at high frequency for that matter. Like any other driver a tweeter has a resonant frequency and a Q factor. Damping of the system, which depends on Q, is a maximum at Fs and drops off at an asymptotic rate of 6 dB/octave both above and below resonance. So, for example, a tweeter with 1k Hz resonance will have approximately 20dB less damping that it does at resonance both at 100 and 10k Hz.
Old 12th March 2017, 10:51 AM   #29
This thread makes me curious how the tweeter and the mid would influence each other on small coaxial systems like this one.
Comparing measurements of the mid and the tweeter (counterpart shorted vs. not connected at all) could probably can answer this. I will try it once the cabinet is ready.
Old 20th March 2017, 03:17 PM   #30
Something to unwind on https://www.youtube.com/watch?v=zrpUDuUtxPM
Multi Stage amplifier bandwidth. rlaury Tubes / Valves 4 8th January 2016 08:20 AM
audio amplifier bandwidth davidel94 Solid State 15 4th March 2013 08:30 PM
Amplifier Testing Procedures; Bandwidth and THD mbeards Equipment & Tools 7 14th December 2012 08:00 AM
Full Range plus Tweeter Anchan Full Range 48 13th April 2012 07:39 AM
High bandwidth switching amplifier Snickers-is Class D 22 31st May 2006 05:28 PM
Copyright 1999-2017 diyAudio
