Sand sandwich - Page 5 - diyAudio
Old 28th March 2004, 12:00 AM   #41
Send a message via AIM to Chris8sirhC
I seem to remember reading an AudioXPress atricle some time ago that tested various methods of bracing, one of them being a sand filled sandwich. I think the results showed that the sand filled sandwich actually raised the db of some of the resonance frequencies. I'm not sure which issue this atricle was in or even what year, maby someone else remembers this article?
Old 28th March 2004, 12:04 AM   #42
diyAudio Member RIP
Originally posted by Vikash
[B]
Perhaps a second PR is the way to go after all.
If the PR has twice the excursion of the driver pointless, sreten.
Old 28th March 2004, 12:32 AM   #43
angel is offline angel  Norway
Someone here mentioned the use of flour. I would advise against that, as flour is highly combustible, in fact even explosive, under the right circumstances.
Anyway, as someone pointed out, while mass may help keep a subwoofer from sliding across the floor, bracing is what will matter the most.
On that note, has anyone tried casting a metal chassis themselves? I imagine that would be rather interesting. Or, at the expense of the seamlessness of a cast, and aesthetics (unless you're looking for the ultimate industrial kick), perhaps welding metal sheets for an enclosure?
Old 28th March 2004, 08:57 AM   #44
Vikash is offline Vikash  United Kingdom
diyAudio Moderator Emeritus
Vikash's Avatar
Pointless? A second PR gives me a little bit more SPL (modeled 106db @25hz in 30l), reduces excursion in all drivers (compression/distortion?) and allows potential force cancellation between passives if I'm to understand correctly.
Was there something other on your mind Sreten?.
"The human mind is so constituted that it colours with its own previous conceptions any new notion that presents itself for acceptance." - J. Wilhelm. (But I still think mine sounds better than yours.)
Old 28th March 2004, 12:16 PM   #45
diyAudio Member RIP
Well Sonus Faber do it, so must be some point.
I didn't know two PR's would reduce the main units excursion
compared to one (with the same tuning frequency).
Your right about distortion being reduced somewhat too.
sreten.
Old 10th April 2004, 02:05 PM   #46
Vikash's Avatar
Bracing doesn't appear to be straight forward with this arrangement. Any suggestions?
Old 10th April 2004, 02:31 PM   #47
diyAudio Member RIP
All you need is an offset vertical brace with a driver cutout,
or just running up the the back of the bass driver.
You could also make the two sides and front double thickness
which will reinforce all but two of the edges, the front vertical
two edges massively, eight edges very well, the only two not
reinforced would be taken care of by the offset vertical brace.
If you go double layer use larger holes on the inside layer,
also note double layer makes it very easy to stagger the
joints, which is better then butt jointed double thickness.
sreten.
Old 10th April 2004, 04:02 PM   #48
5th element's Avatar
My sealed XLS 10 are in double thickness MDF boxes with two crossbraces. They are 60cm tall with one brace at about 20cm up and the other at about 40. these are rock solid even when the XLS shift lots of air.
What the hell are you screamin' for? Every five minutes there's a bomb or somethin'! I'm leavin! bzzzz! Now with website! www.5een.co.uk under construction.
Old 10th April 2004, 04:13 PM   #49
I forgot to mention the lower cavity between teh bottom of the cabinet and the 20cm brace is filled with small stones in platic bags. The crossbraces are shelf braces too. similar to the ones you drew in a your cabient that hold the drivers magnet but mine are perpendicular to the driver. Ie from front to back of the cabinet not top to bottom. A small cube that size made out of 36mm MDF is going to be very rigid anyway, obviously bracing will help increase regidity but I wouldnt worry about it too much.
Nice animation and pics btw
Leak Sandwich Ropie Multi-Way 37 8th February 2014 01:36 AM
Sandwich box amplifier ash_dac The Lounge 6 29th October 2006 01:12 PM
Suggestions for ult. sandwich Christof Multi-Way 11 28th July 2004 01:06 PM
mdf sandwich quessie mattpman Multi-Way 7 16th April 2002 12:52 PM
Copyright 1999-2017 diyAudio
