Old 15th March 2004, 08:42 PM   #1
Jim85IROC's Avatar
Send a message via AIM to Jim85IROC
Default crossover changes for a sloped baffle?
Typically, would crossover changes be necessary to impliment a sloped baffle to time-align the drivers, or in reverse, to use a flat baffle with a crossover designed to be used with drivers on a sloped baffle? I'm heavily considering building the Usher CP-737s, which have the tweeter on a sloped baffle to time-align it with the woofer, but I'm leaning toward a flat baffle so that I can position the tweeter closer to the mid. Can I still use that crossover without causing a collapse of the universe?
Old 15th March 2004, 09:09 PM   #2
Bill Fitzpatrick's Avatar
Enough of a slope to time align the drivers means you will have to consider the off axis response of the driver rather than the on axis response. The crosssover will, in most cases, need to modified.
Old 16th March 2004, 11:54 AM   #3
Jim85IROC's Avatar
The usher in question has what appears to be approximately a 10 degree tilt, which I would imagine wouldn't be enough to effect too much except the highest octave of the response, and the tweeter filter is a simple 3rd order with a series resistor for attenuation. Since I tend to like my highs a tad bright anyway, I guess I can take a chance with a flat baffle.
Old 16th March 2004, 01:18 PM   #4
rabbitz is offline rabbitz  Australia
rabbitz's Avatar
There is a paragraph in the Loudspeaker Design Cookbook the states that "experts" often suggest the inverted driver position when you use odd order networks with reversed polarity for the tweeter on third order in order to compensate for polar tilt. The theory is that driver geometry would give you +15º tilt and odd order filter give you a -15º tilt would sum to a 0º Zero Delay Plane.
For this to work the drivers have to have horizontal and vertical offsets so the tan of this would be 15º. In other words:
Tan 15º = (horizontal offset / vertical offest)
Vertical offset is the centre distance between the drivers.
Horizontal offset is the difference between the voice coil centre of the drivers (use the centre of the motor driver frontplate).
Phew! Hope this might be of some help, if you can follow my explanation.
Old 16th March 2004, 02:33 PM   #5
Jim85IROC's Avatar
The crossover schematic indicates normal polarity on the tweeter, and the accompanied write-up doesn't mention reversing the polarity.
The plot thickens.
Old 17th March 2004, 02:06 PM   #6
rabbitz's Avatar
If it's a proven design you are better off sticking with it.
This is just a method to help with alignment on a flat baffle. BTW, my understanding is that the preferred polarity for 3rd order is reversed, but it all come down to listening tests in the end.
BSC, sloped baffle? PeteMcK Multi-Way 1 2nd July 2009 02:43 AM
1st or second order crossover for sloped baffle fin1bxn Multi-Way 5 15th September 2008 07:17 PM
Crossover for open baffle: please need help! Calamaro Multi-Way 16 10th September 2008 01:07 PM
Possible to emulate a sloped baffle? Mal P Multi-Way 11 8th April 2005 12:18 AM
Does sloped baffle affect X.O. dvdwmth Multi-Way 3 3rd June 2004 09:47 PM
Page generated in 0.09212 seconds (74.80% PHP - 25.20% MySQL) with 10 queries
