Goldwood 18" for OB sub
Old 16th March 2004, 06:37 AM   #11
bbaker6212 is offline bbaker6212
I don't understand why so many people here are so focused on xmax. With drivers of this size and efficiency I don't think xmax is really important as I don't think there will be any problem with moving enough air. That said, I think it's better to have low xmax drivers as they are more linear (less distortion) if used within their excursion limits. That's probably contraversial here, but that's my opinion.
Btw, excuse my ignorance but what is "no."
I haven't decided to go with the Goldwood just yet. I'm actually leaning towards the Pyramid at this point - I just wish I could get a hold of it's response and impedance plot.
Deon, that Goldwood 215 driver is too inefficient for me at 87db. I don't want to have to run six of these A 20 oz magnet and foam surrounds? This is stretching things as far as cheapness goes.
-Brad-
Old 16th March 2004, 09:05 AM   #12
R.I.P.
Originally posted by bbaker6212
I "arrived" at the bump by looking at the response graph that Goldwood sent me. You can see it by clicking on the "104db bump" link I posted above.
Well in that case the quoted parameters are miles out ?
sreten.
Old 16th March 2004, 11:13 AM   #13
Svante is offline Svante  Sweden
Svante's Avatar
sreten.
Or the FR measurement is done in a closed box? It seems as if the resonance frequency is some 45 Hz, or a factor 52/30=1.7 higher than free air. Q in the box would be 2.6 or something, which is 2.6/1.07=2.4 times. (I get these figures by overlaying a simulation on the graph).
Anyway, since both Q and fres are higher than stated in the data sheet, I suspect that the box used is not infinitely large. Since the Vas is 524 litres, the box need not be *that* small to end up with this curve.
This would maybe also explain the baffle step (?) seen above 1kHz.
Simulate loudspeakers: Basta!
Simulate the baffle step: The Edge
Old 16th March 2004, 11:37 AM   #14
R.I.P.
Hi Svante,
but we are talking open baffles here.
Baffle step above 1K doesn't happen for an 18" unit.
(The graph also states 1/2 space, i.e. a large baffle)
The graph also shows Fs at 27Hz.
Something is seriously wrong, modelling or measurement wise.
sreten.
Old 16th March 2004, 12:41 PM   #15
Svante's Avatar
Hi Svante,
sreten.
Yes, I realise that you are talking open baffles, but I suspected that the FR graph (but not the impedance graph) was measured in a large but not infinitely large box. Hmm, I am now realising that the measurement is *not* from the manufacturer as I thought, then I *do* wonder about the measurement conditions (and I don't trust the statement "half space" (yet at least )).
Anyway, I have seen such descrepancies between impedance and FR before on I think seas or vifa drivers. They state that they measure as Peerless (ie in a wall of an anechoic chamber), but it does not add up unless one uses a box for one of the graphs.
You are right that the baffle step cannot occur at 1kHz for a 18" driver, silly me.
Old 16th March 2004, 01:36 PM   #16
Roscoe Primrose is offline Roscoe Primrose  United States
I don't understand why so many people here are so focused on xmax. With drivers of this size and efficiency I don't think xmax is really important as I don't think there will be any problem with moving enough air. .
Efficiency has absolutely nothing to do with how much excursion/xmax you need in your drivers. For an 18" driver to produce a given SPL at a given frequncy in identical enclosures, a driver that's 80dB/W/m and one that's 105dB/W/m will both have to have exactly the same excursion, it'll just take a lot more power to get that excursion with the 80dB/W/m driver...
Peace
Old 16th March 2004, 01:40 PM   #17
OMNIFEX is offline OMNIFEX  Jamaica
OMNIFEX's Avatar
bbaker6212
OMNIFEX
Well, when you decide to reproduce 80 Hertz down, its the
xmax that gives you the volume. This is why you can have
an 87 dB woofer with 12 mm xmax out shine a 92 dB woofer
with 3 mm xmax.
bbaker6212
OMNIFEX
no.= The reference efficiency of a driver with a half-space acoustical load. I tend to use this more than the published
1 watt, 1 meter dB measurements on a spec sheet.
Put it like this. The Eminence Killomax 18 is known for
being inefficent in the Pro Audio World. This is
understandable due to the 9.8 mm xmax. The Goldwood
1858 is ruffly 3 dB less than the Killomax and has a 3.36 mm xmax. Most ifnot all 3 - 6 mm xmax 18 inch woofers have a
3 db lead over the Eminence Killomax 18.
Eminence Killomax 18: xmax 9.8 mm, 93.76 dB 1 watt, no. 1.433%
Eminence Omega 18: xmax 5.5 mm, 98 dB 1 watt, no. 2.997%
Goldwood 1858: xmax 3.36 mm, 91.61 dB 1 watt, no. 0.873%
As you can see this 18 has the efficency of a 12
subwoofer, and, the xmax of an 8 inch speaker.
Not to mention, you are using an open baffle, so
these numbers will reflect the amount of volume
you will encounter, considering you will not have
any spl gain from the cabinet.
OMNIFEX
Old 16th March 2004, 04:29 PM   #18
The FR graph did come drom Goldwood.
I still don't understand how you are calculating ".no"
Also, I'm not sure it's accurate to say the Goldwood 1858 has an efficiency of 92db when it has an output of 104db at 45hz - if the FR graph from Goldwood is accurate. Also, stating the "xmax of an 8 inch driver" doesn't make any sense to me. Xmax is excursion right? So what does the diameter of a driver have to do with it's excursion? This statement just makes me believe you have a bias against this driver (maybe because it is cheap?) instead of using accurate and logical analysis.
No, 80hz or not, xmax is not what gives you the volume. Xmax *and* surface area is what gives you the volume. So two 18" drivers with 4mm xmax will suffice for one 18" with twice the xmax. The only reason the lower efficiency, high xmax, driver will "outshine" it is if you feed it more power. This is not my case. I will be running low power, thus I want high efficiency.
-Brad-
Old 16th March 2004, 06:18 PM   #19
If you have an efficiency of 98-107db from 30-45hz with only 1 watt (running two drivers), how much excursion do you think you need? It's not like you're going to be running 100 watts into the thing! This is in a home, not a stadium.
-Brad-
Old 16th March 2004, 06:23 PM   #20
OMNIFEX's Avatar
bbaker6212
OMNIFEX
Does the graph state the measurements are from an open baffle?
bbaker6212
OMNIFEX
Actually, Bass Box Pro is doing the math
bbaker6212
OMNIFEX
Well thatís the keyword IF DIY Builders know specs are not always what they seem. I can tell you that with such a high QTS, this woofer is getting its gain from being in a small enclosure. Parts Express list the QTS as 1.04 Now. With a small driver with a QTS of this size, you can build an enclosure and try to gain a flat signal. But, having an 18 inch woofer with QTS of 1.04? You are looking at are
Humongus sealed box.
bbaker6212
OMNIFEX
Yes.
bbaker6212
OMNIFEX
Large drivers that are designed for sealed enclosures must have a large Xmax to produce bass. If they donít, they will not produce enough SPLís at low frequencies, due to running out of xmax.
bbaker6212
OMNIFEX
Bias?
Dude, the analysis I gave (Killomax, vs, Omega, vs, 1858) is as logical, as you can get. Maybe you need to download WinSID Pro
Punch in the numbers, feed all three the same wattage, checkout the excursion, and, SPL graphs, and see what I mean.
If you want to purchase the Goldwood 1858, by all means do so!
However, you did ask for opinions, and, we gave our opinions, in which no one was endorsing this driver. Its not because its cheap. Its because it was designed to work in a sealed cabinet that will increase its gain. This speaker has a large QTS, and, the only way
to increase the SPLís is to house it in a box smaller than its minimum enclosure requirements. You are using an open baffle. Where are you going to get the gain from?
bbaker6212
OMNIFEX
Ok. It seems like your mind is already made up, regardless of what anyone says. Just keep in mind High Efficency 18ís have an EBP of 100. The 1858 are in the 20ís. But, I guess that doesnít matterÖÖÖ
You obviously have some kind of trick to make two Goldwood 1858ís be more efficient than one Eminence Omega 18 in an
open baffle.
Once you finish building your open baffles, you can tell us what you did to accomplish such a fete.
Please keep in mind that I was in no way in my posts
being sarcastic. I just feel that I am not giving you the
answers you are looking for. So, I let someone else share
their thoughts.
Best Regards,
OMNIFEX
Goldwood 18" for OB subHide this!Advertise here!
Goldwood G-8003 8" Fullrange Carlp Full Range 16 3rd August 2013 03:46 PM
anyone has experience with goldwood 10" woofers ? angeloitacare Multi-Way 0 6th January 2008 05:28 PM
Goldwood 15s on OB? Pano Multi-Way 0 6th January 2007 06:23 AM
8" 4 ohm heavy duty woofer/midbass needed, who's Goldwood? eRiCdWoNg Multi-Way 11 29th February 2004 06:11 PM
