hi, has anyone tried bypassing dayton metalized polypropylens such as, 20.mfd in a passive crossover, with orange drop .1 mfds with any improvements? not the best for bypass i know but just happen to have some laying around, and thought they might be worth trying, untill i can get something better. thanks for any input, crippledchicken
#2 |
Well, why don't you try it and judge for yourself?
#3 |
Hello,
I would expect your results would be good. I have done the same with small .1uf Solen poly caps with good results. Trial and error is best. Good Luck. Kevin Lee |
#4 |
hi fellas, thanks for your input. i didn't know if someone had maybe tried this particular combination or not so, i'll give it a whirl and see what happens. thanks again, crippledchicken
| Output of preamp drops when overdriven | oliverwestby | Tubes / Valves | 7 | 1st February 2009 02:36 PM |
| 12 volts drops to 6 when amp is powerd on | DAKOS | Car Audio | 22 | 1st February 2009 02:19 PM |
| Rectifier that drops lots of volts? | dsavitsk | Tubes / Valves | 8 | 30th November 2006 01:40 PM |
| BOZ supply voltage drops to 1/2?? | Kermit | Pass Labs | 11 | 11th December 2002 07:08 PM |
| Page generated in 0.07660 seconds (70.14% PHP - 29.86% MySQL) with 10 queries |
