SEAS A26 build
SEAS A26 build
Old 4th February 2017, 02:06 PM   #21
zman01 is offline zman01  Bangladesh
SEAS A26 build
What's cooking with the A26 today BK?
Old 4th February 2017, 02:50 PM   #22
picowallspeaker is offline picowallspeaker  Italy
picowallspeaker's Avatar
Originally Posted by akarma 76 View Post
What affordable tweeter i can use in A26 kit? May be Seas H1189 or Wavecor TW030WA11-01?
What about this ? 25-2234S - 25mm Hi-Res Tweeter - TB SPEAKER CO., LTD.
But something like the Wavecor or the seas DXT, both with the waveguide, would be a better match with the 25 cm woofer made by Seas
Everything under and above heaven is in utter chaos
Old 4th February 2017, 03:11 PM   #23
akarma 76 is offline akarma 76
Originally Posted by picowallspeaker View Post
What about this ?
I don't think it's a good idea.
Wavecor TW030WA11-01 looks like great pretender for the kit by specs. But a few information. Seas H1189 is good as it seems too.
But the most disturbing moment for me is 10" Seas A26RE4 capability to perfom in midrange region. It bothers me.
Old 4th February 2017, 03:32 PM   #24
Well, "it holds" till 1 ( 1k5) kHz then it looses...
Ideally you'd need a 25 cm waveguide to find the same dispersion characteristic at crossover frequency. But it's too big and the nuisance of the horn-effect might be not acceptable ( because of the 3 " driver inside which is too big ).
Till 20 cm diameter ( effective :16-17 cm )it's acceptable, as I did an experiment with an 8" and a 2 " in such big waveguide ( actually I have some dead speakers so ...).
I stopped using woofers bigger than 6 1/2 "
Old 4th February 2017, 03:41 PM   #25
Flaesh is offline Flaesh  Russian Federation
Flaesh's Avatar
Wavecor TW030WA11-01..
Test Bench: Wavecor TW030WA12 30-mm Cloth Waveguide Loaded Tweeter
"The TW030WA11, which is the 4-Ω version, was featured in the November 2014 Voice Coil issue."
flesh flash flush
Old 5th February 2017, 02:00 AM   #26
bk856er is offline bk856er  United States
bk856er's Avatar
SEAS A26 build
Made the important baffle cuts. The vent was a bit fiddly, but came out great. Hopefully I can make some progress on the bracing tomorrow.
BK
Old 5th February 2017, 10:18 PM   #27
bk856er's Avatar
SEAS A26 build
Got the bracing sorted today, well one speaker at least. I'm sure the neighbors love my weekend outdoor routing.
BK
Old 6th February 2017, 03:41 AM   #28
SEAS A26 build
Looking good.
"Music" to their ears?
Old 13th February 2017, 01:22 AM   #29
bk856er's Avatar
SEAS A26 build
All glued up!
BK
Old 13th February 2017, 01:28 AM   #30
SEAS A26 build
All glued up!
BK
Good to see... nearly there!
SEAS A26 buildHide this!Advertise here!
Seas A26 speaker? bk856er Pass Labs 35 22nd January 2018 04:32 AM
SEAS A26 Speaker Kit HiFiHarry Multi-Way 62 28th December 2017 07:07 AM
time align the seas a26 kit ? norman bates Multi-Way 11 29th September 2016 06:09 AM
SEAS A26 crossover frequency nugat Multi-Way 5 7th June 2016 08:04 PM
SEAS A26 in oversize cabinet nugat Multi-Way 8 16th May 2016 05:04 PM
