SEAS A26 build
SEAS A26 build
Old 19th June 2017, 11:18 AM   #91
frankmalz is offline frankmalz  Germany
hi
so you prefer the A26 over the 4pi?
Yes, for my situation i prefer my special A26 in 82l.
The sound is more full bodied- for this you need definetly subwoofers for the 4pi.
The 4pi is a great speaker but i dont have the space for two additional subwoofer.
Frank
Old 19th June 2017, 01:05 PM   #92
akarma 76 is offline akarma 76
Fullrange + H1411 is good idea. But you need more superior product than cheap Visaton. Tang Bang for example. Xover in that case must be moved in 500-700Hz region for most quality. It will be nice in that way.
Old 19th June 2017, 01:07 PM   #93
Bas Horneman is online now Bas Horneman  Netherlands
diyAudio Moderator Emeritus
Bas Horneman's Avatar
Which tang band? PS cheap does not necessarily mean bad.
If you can see the speaker cone move...it's not hifi.
Old 19th June 2017, 01:11 PM   #94
May be W4-1320 or W4-1337. Medium price range.
Old 19th June 2017, 02:32 PM   #95
phivates is offline phivates  United States
I believe audiopath is referring to the A35, which had two chambers connected by a slot vent. I should do that with some of my surplus boxes and compare. The A 25 leaks LF for the sake of a small box. Otherwise it is a classic. Did epi copy it with the four layer vc woofer and low fs tweeter or is this another basic approach that has been around since day two?
Old 19th June 2017, 02:46 PM   #96
Yes, maybe...
But i am not so good in loudspeaker development. I like the Visaton very well - you can listen very long without getting tired to the sound.
Maybe i check your suggestion with a Fostex FE103S which i have somewhere...
Frank
Old 19th June 2017, 02:49 PM   #97
Wow, the Tang Band W4-1320SIF
https://www.oaudio.de/Lautsprecher-S...4-1320SIF.html
looks very nice
SEAS A26 buildHide this!Advertise here!
SEAS A26 Speaker Kit HiFiHarry Multi-Way 57 11th September 2017 08:45 PM
Seas A26 speaker? bk856er Pass Labs 30 19th June 2017 05:04 AM
time align the seas a26 kit ? norman bates Multi-Way 11 29th September 2016 06:09 AM
SEAS A26 crossover frequency nugat Multi-Way 5 7th June 2016 08:04 PM
SEAS A26 in oversize cabinet nugat Multi-Way 8 16th May 2016 05:04 PM
Copyright ©1999-2017 diyAudio
