Mating de10 to a 12 inch driver - diyAudio
Old 30th December 2016, 08:01 PM   #1
donovas is offline donovas  South Korea
Default Mating de10 to a 12 inch driver
is there a 12incher suitable for de10 compression driver? Preferably an eminence product.
I wanna build a 2 way horn and de10 is the best choice for me
Old 31st December 2016, 04:51 AM   #2
LineSource's Avatar
For good sound quality and smooth polar pattern match:
B&C recommends a 2.5kHz crossover for the DC10. B&C datasheet shows a steep SPL drop starting at 1.5kHz.
HOME AUDIO not PRO POWER: For good sound quality and smooth polar pattern you could mount the DC10 to a narrow 60H x 40V horn and simulate a LR4 crossover at 1.6kHz to a 12" Eminence Delta Pro 12A.
If you need a wider polar pattern horn, like the 90H x 40V SEOS or QSC, a 10" midrange would be necessary for a smooth 1.6kHz polar match. Eminence Kappalite 3010HO might work. The Faital 10PR410 would be a better choice.
Old 2nd January 2017, 06:06 AM   #3
how about delta 12a, the non pro version? they look awfully similar specwise if youre only considering them for home usage or im missing something.
http://www.parts-express.com/pedocs/...ions-44317.pdf
Old 2nd January 2017, 08:00 AM   #4
LineSource's Avatar
The Eminence Delta 12A cone breakup around 1.6kHz makes it undesirable. This SPL profile is often used for lead guitar 3rd harmonic projection.
A good quality 10" midbass like the Faital 10PR410 would allow a clean sounding 1.8kHz LR4 crossover for the DE10 mounted on a more home-audio desirable 90H x 40V polar pattern horn. At the crossover frequency, you want the polar pattern(early beaming) of the midbass to match the horn.
Typically, a 1.3kHz crossover is used between a quality 12" midbass and a 90H x 40V waveguide. The B&C datasheet recommends a 2.5kHz minimum crossover frequency for the DE10.
Old 2nd January 2017, 09:06 AM   #5
TBTL is offline TBTL  Germany
Why is it the best choice?
For hi-fi you can cross a compression driver lower than recommended. Maximum SPL drops dramatically, but unless you like to listen loud that doesn't matter.
Old 2nd January 2017, 02:21 PM   #6
Budget and availablity
Old 2nd January 2017, 02:22 PM   #7
So if i were to listen at a reasonable level, i could sub de10 in place of de250? (With proper crossover adjustment)
And what kind of volume are we talking here?
how to fit 10 inch driver into 12 inch hole? dogshome Multi-Way 12 25th November 2016 09:15 PM
Inexpensive (< $50 ) 12 inch Driver for 9.5 foot (2.89m) TL justinzane Subwoofers 7 12th April 2013 03:19 AM
Resistor to change Qts of 12 inch driver ashok Multi-Way 0 26th May 2007 03:19 AM
JL W3v3 10-inch or 12-inch? bad1301forlife Subwoofers 1 1st April 2007 10:05 AM
8 inch driver for Isobarik system with 12 drivers Joenobody Subwoofers 17 1st January 2007 10:07 PM
Copyright 1999-2017 diyAudio
