Why is off-axis horizontal MTM bad?
Old 12th March 2004, 05:23 PM   #1
azira is offline azira  United States
Default Why is off-axis horizontal MTM bad?
I'm starting my research on building a center channel. It seems like the most popular designs are MTM (2/2.5way) or WMTW (3-way) type of designs. I also read a lot that MTMs have pretty crummy off-axis behavior. It seems like people are refering to nodes and lulls created by the 2 element "line array" of the Ms for this conclusion. But if the CC is horizontal, wouldn't it mean that you are always listening on-axis? My listening angle would be something like +/- 30deg.
thx.
Danny
Old 12th March 2004, 05:47 PM   #2
R.I.P.
At c/o a vertical 2-way MTM can be treated as a 3 element line array.
Horizontal dispersion is not a problem, but vertically due to the
3 elements dispersion has more nulls than a MT 2-way.
(Typically 4 versus 2, and the angle of the 1st null is smaller)
When turned on its side, so the vertical dispersion becomes
the horizontal dispersion basically the extra nulls are not
a good idea in terms of horizontal seating position coverage.
For a horizontal box :
--T--
WMW
Is the way to do it, have vertical MT array with woofers either side.
sreten.
Old 12th March 2004, 06:15 PM   #3
officeboy is offline officeboy  United States
Send a message via MSN to officeboy
As you can see.. It's not that pretty, unless you’re really off axis.
Old 12th March 2004, 06:52 PM   #4
Ok, I just missed something. I've also been reading up on line arrays and I thought the papers indicated increased sensitivity on-axis with line arrays while the lulls started appearing off-axis. The sound field becomes more like a cylinder so any point vertically on-axis should be the same as any ohter point. Is this wrong? That's the way it's indicated in the vpr excel program.
Old 12th March 2004, 07:19 PM   #5
R.I.P.
Is only true for a perfect line array, e.g. a ribbon or similar.
Or lots of units at frequencies with wavelengths greater than the spacing.
sreten.
Old 12th March 2004, 07:26 PM   #6
Bill Fitzpatrick is offline Bill Fitzpatrick  United States
Bill Fitzpatrick's Avatar
Where is that ripple tank program located. I want to play.
Old 12th March 2004, 07:29 PM   #7
http://www.falstad.com/mathphysics.html
I can spend hours playing with these things.
Old 12th March 2004, 07:41 PM   #8
sreten.
But when the wavelength starts to equal or become shorter than the spacing, the dispersion pattern is on both axises?
Old 12th March 2004, 07:50 PM   #9
R.I.P.
Oh yes, sreten.
Old 12th March 2004, 07:51 PM   #10
Timn8ter is offline Timn8ter  United States
Timn8ter's Avatar
It's interesting how much it cleans up when you add a 4th source at nearly the same point as the center source. This seems to simulate what would happen if you add a mid-ranger under/over the tweeter. This app is way
Why is off-axis horizontal MTM bad?Hide this!Advertise here!
Horizontal MTM Center channel: avoiding off-axis nulls DcibeL Multi-Way 27 10th October 2009 06:57 PM
Horizontal woofers steve_mak Multi-Way 5 5th April 2006 12:28 PM
OPT axis tenderland Tubes / Valves 2 8th March 2005 01:54 AM
