Old 12th March 2004, 07:05 AM   #1
blu_line's Avatar
Default front or rear port
I am designing and building my new WMT speakers with VIFA drivers. The Woofer needs a vented box.
What is the difference and what things i need to consider to use a front OR rear vent/port ?
Simon
Old 12th March 2004, 02:08 PM   #2
gary f is offline gary f  Canada
gary f's Avatar
Why not try the down firing port. I am building a design with this type of port and maybe next week, i will finaly know if it is as good as i think...
F
Reflex port under the cabinet ??
Old 12th March 2004, 02:19 PM   #3
moving_electron's Avatar
Location: Where the rain does fall but the trees grow tall
The concensus seems to be that:
1) The bass response is the same in either case.
2) the frequencies out of the port are low enough they do not cause issues of interacting with the output of the woofer.
3) there are effects from the port acting like a pipe and when rear facing this effect is difussed so is not an issue.
4) Many have used front ports without running into practical effects of this pipe issue
5) rear port means the speaker cannot be flush against the wall. Others say why would you do that anyway.
Old 12th March 2004, 02:20 PM   #4
Timn8ter's Avatar
Nice summary!
Rear port and front port barry.childs Multi-Way 10 27th February 2009 10:46 AM
Front or rear port placement? JLC7 Multi-Way 14 26th May 2008 09:04 PM
Rear or front port? Speek Multi-Way 1 7th September 2005 09:58 AM
rear port vs front port Jimmy154 Multi-Way 22 6th March 2004 09:38 AM
Rear vs. Front Port squidbait Multi-Way 11 21st January 2004 01:10 AM
Page generated in 0.06638 seconds (73.05% PHP - 26.95% MySQL) with 10 queries
