Hi Kuei
Just two quick question regarding XL Baffle, both concerning the 'Height above floor (mm)' parameter: 1. Is this measured at the centre of the cone, or at the bottom of the driver's chassis? 2. How is this parameter and the predictions that come from it affected if you slope the baffle backwards (for example at a slant of 20 degrees from verticle)? This will surely smooth the upper-bass midrange response not so? And how will it affect low-end response? ![]() Ok, that was more than just two questions, but thanks anyway. Thanks, Deon
Reality is not digital, an on-off state, but analog. Terry Pratchett - Moving Pictures |
#2 | ||
Previously: Kuei Yang Wang
Konnichiwa,
XLbaffle offers a first order approximation, not "absolute fact" data, take it's output as a general guide and allow plenty of error margin. It was designed more to illustrate trends than to produce absolute data. That "edge.exe" thing is much more accurate than XLbaffle. Sayonara |
#3 | |
#4 | |
Konnichiwa,
Do you think the math in the Edge could be "convoluted" sufficiently to give a single excel worksheet row per frequency? Then I'd update XLBaffle and XLBox with that math (full crdit to you for this of course).... Sayonara |
#5 | |
http://www.tolvan.com/edge/QuicknDirtyEdge.xls |
| Kuei Yang Wang's 6sn7 linestage | Yaho | Tubes / Valves | 4 | 24th March 2008 07:35 PM |
| Linestage suggestion for Kuei Yang Wang's phonostage | Yaho | Tubes / Valves | 5 | 12th February 2008 09:06 PM |
| PING- Kuei Yang Wang | Magnetar | Multi-Way | 21 | 23rd November 2005 05:44 PM |
| Yet another new Gainclone (YANG?) | jtsjf | Chip Amps | 6 | 8th November 2004 10:02 PM |
| A question for Kuei Yang Wang | Igla | Multi-Way | 3 | 12th July 2003 11:59 PM |
| Page generated in 0.09399 seconds (78.26% PHP - 21.74% MySQL) with 10 queries |
